zombie wrote:Oh look, more photos from the RAC driving centre..
These are Gram Lights by Rays Engineering
HOT!!
Sasso wrote:Based on looks...needs lowar, but of course not necessarily going to help handling. Def could do with some sway bars or stiffer suspension though, lots of roll form the looks.
CoffeeBoss wrote:Sasso wrote:Based on looks...needs lowar, but of course not necessarily going to help handling. Def could do with some sway bars or stiffer suspension though, lots of roll form the looks.
But, does more roll does imply less mechanical grip?
Stock NC's produce more cornering gee's then any previous MX5. For the same reason, people who race NC's (eg. Zane) will tell you that the greater wheel travel afforded by the NC's design, like an open wheeler, means that on some circuits the racing line for an NC is more like an open wheeler and quite different to an NA/NB. More suspension arc means the suspension can carry more load/unload, rather than running out of travel which can result in compression pushing the tires beyond their grip limit. Zane described this exact scenario too me with regards to driving NA/NB vs NC around Oran Park (RIP!).
I used to think more roll = less grip, but the more cars I drive, the more I think chassis design principals are not that simple!
CoffeeBoss wrote:Before this goes even further OT, I think you've probably highlighted why most road users would choose sways - because they inspire more confidence in most drivers. It's not really a question of mechanical grip.
FWIW, Chris only uses a slightly thicker rear sway in his NC's to neutralise the cars handling. But as you've said, suspension choice, tire choice etc all play a role as well.
For trackdays and khanas on billiard table smooth surfaces (race cars), a stiffer roll is obviously an advantage combined with more rubber etc. But for a road car, not always the case.
fundies wrote:orx626 wrote:Just for a laugh....and so I could move the car....19 x 9 with a 35P offset and 245/35 R19 rubber.
Fills the guards a bit too well.
BLING!!!!!!!!!!!!
Users browsing this forum: No registered users and 145 guests
