Best track day tyres for stock NA8 rims?
chrisd
Postby chrisd » Mon Apr 19, 2010 10:39 pm
I have a standard NA8 and intend to do some track days and the upcoming NSW Aust Tarmac Challenge. Can someone suggest suitable tyres as I want to keep the original rims ? Chris
Postby Hammer » Mon Apr 19, 2010 11:06 pm
What type? Are you after slicks, semi-slicks or road tyres?
chrisd
Postby chrisd » Tue Apr 20, 2010 2:23 pm
sport road tyres or semi slicks depending on what is available .
Guran
Vehicle: ND - 1.5
Postby Guran » Tue Apr 20, 2010 5:17 pm
If you're just starting out with doing trackdays, I'd recommend you look at Bridgestone Adrenalin RE001, cost around $120 per tyre. They're cheap and give decent grip in the dry. Can be a bit loose in the wet although I've found them fine for road use. I've been using them for the last 15 months and got 11 trackdays out of the first set. They also helped me to a NA6 club record at Wakefield Park.
If you're reasonably experienced with trackdays and are looking for something a bit better, then the Dunlop Z1 Star Specs have been given good wraps. Cost about $200 per tyre (you can get them from Gary's Motorsport near Eastern Creek). Star Specs seem to be the next best thing to R spec semi-slicks but are more useable for the street, with very good wet and dry grip. If you're looking at competing in the stock class at MX-5 Club NSW trackdays, then you would need to check whether Star Specs are permitted.
Semi-slicks are a waste of money for road use, IMHO. You're paying at least $300 per tyre and they will wear out quickly because they are much softer than road tyres. Plus they can be a bit skatey when they're cold - you need to work them up to temperature on the track before they give optimal grip. Better to get a second set of rims and have a set of semis for trackdays and sport road tyres for everyday. The most commonly preferred semi-slicks for MX-5s seem to be Bridgestone RE55S, Dunlop D01J, Toyo R888, and Kumho V70A or V700. I'm currently using the RE55S and they're excellent. A lot of guys are using the Kumhos with great success.
BTW if you're planning on entering the Dutton Rally, I suggest you should give serious consideration to fitting a rollbar, especially if there are any hillclimb or rally stages involved this year.
chrisd
Postby chrisd » Tue Apr 20, 2010 9:06 pm
thanks . good advice. I'll have a look at the Dunlops but think the second set of rims and semis is a good suggestion. Dutton , now known as ATC, is a one day event at Easter Creek this year. Chris
Hellmun
Postby Hellmun » Tue Apr 20, 2010 11:06 pm
You really need to pick what category your competing in first. Standard classes usually require street tyres, modified classes usually allow semi-slicks and unlimited mods is usually the domain of slicks. Prod sports, supersprints and club level events work roughly on that criteria. When you pick which class of tyre your going to need you'll get much more specific advice. e.g compound, brand , size and type etc.
chrisd
Postby chrisd » Wed Apr 21, 2010 10:20 am
the ATC rules require road legal tyres so that narrows it down . Do NB rims fit my NA8 ? That would get me into 195 50 15 size which gives more choice.
NZMiata
Postby NZMiata » Wed Apr 21, 2010 10:55 am
NB 15" wheels definitely fit an NA8. Lots of people run them. They look great too!
Red 1994 MX-5
