What oil should I use for my new cusco RS 1.5way?
- mxfive95
Hi all,
I'm going to install my new Lsd this wknd with my mechanic and wondering which oil to use. It's going into my original diff housing on an NA8.
Cheers craig
Cheers craig
The bumper sticker on my porsche
"My other car is an mx5"
- Hellmun
- Vehicle: NB8B - Turbo
Well I've got a 2 way Tomei Traxx and I've ran Royal purple 75-90 gear oil. Which I managed to burn.... Penrite Sin 75 has been good so far. It seems to have more lim-slip additive as it reduced the chattering more than the Royal Purp. I will say it was an endurance race that killed the royal purple which most people won't use their cars in
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
SAE75W/90 Gear oil - most of the WA crowd uses Redline Shockproof.
You will need 1 liter or 1.06 quartz (two bottles) for a NA8/NB8 diff.
I suspect the NC will require a little more.
Les
Les
- Charlie Brown
mx52nv wrote:SAE75W/90 Gear oil - most of the WA crowd uses Redline Shockproof.
Les
The NC is actually less. 0.7 litres GL-5 90 for the diff. Gearbox is 2.1 litres GL-4 75W 90.
I use Penrite Sin 80 (80W-140) in my Mazdaspeed 1.5?way.
Changed it after the first track day break-in and its been excellent (quiet, no chatter) ever since..
- Locutus
i'm surprised all oils mentioned so far are not labelled LSD compatible by their manufacturers.
i'm in the same situation and am currently eyeing motul 90PA.
Hrmz kazz make their own LSD diff oil I was thinking of bying a tin of that.
Can you use the same oil that you use for the gear box MT90?
every ounce counts
- mx52nv
- Vehicle: Non MX-5
Cusco LSD Oil Group Buy?
Les @ MX5 Shop
Les @ MX5 Shop
Sorry I'm not really willing to wait for another GB.
I think you can get it locally, around 60 dollars for a 1 L tin.
every ounce counts
- Hellmun
Locutus wrote:i'm surprised all oils mentioned so far are not labelled LSD compatible by their manufacturers.
I called Hi-Octane in Sydney when I got the Tomei Diff as they're the australian distributor. He said they run the Royal Purple Max gear with all their cars. They've made a few weapons so figured they were a good source. The Royal purple lasted 30,000km but then it's tracked non-stop. So I probaly should've changed it earlier...
My NA8 has got an unknown LSD in it. Low speed / tight maneuvering is hard work with juddering and all sorts of funny noises so its definitely an aftermarket one of some sort.
I have got in my shed an unopened bottle of Limslip 90 Extra heavy duty SAE 80W90, API GL-5/6. Would this be okay to use?
- fattima
Are you sure it is an LSD? Could be a locked diff by the sound of it.
I used to run Limslip in my plate type diff of my Escort with no probs.
I don't think it is locked. I have not really had a chance to 'make progress' properly but it feels like my old Mk1 MR2 did with a harsh KAAZ clutch type LSD...behaved like a locked diff at low speed but felt normal on the move.
I just want the thing to be a bit quieter and less juddery. I'm thinking part of the problem may be that it has not been done in a long time!
- 16bit
that limslip 90 sounds fine. those are the same oil specs that kaaz recommend too.
i just bought some nulon lsd oil which has simlar specs to those.
http://www.nulon.com.au/products/SAE_90 ... ntial_Oil/
Users browsing this forum: No registered users and 207 guests
