What oil should I use for my new cusco RS 1.5way?
mxfive95
Postby mxfive95 » Thu Apr 15, 2010 10:35 pm
Hi all,
I'm going to install my new Lsd this wknd with my mechanic and wondering which oil to use. It's going into my original diff housing on an NA8.
Cheers craig
The bumper sticker on my porsche
"My other car is an mx5"
Hellmun
Postby Hellmun » Fri Apr 16, 2010 12:21 am
Well I've got a 2 way Tomei Traxx and I've ran Royal purple 75-90 gear oil. Which I managed to burn.... Penrite Sin 75 has been good so far. It seems to have more lim-slip additive as it reduced the chattering more than the Royal Purp. I will say it was an endurance race that killed the royal purple which most people won't use their cars in :mrgreen:
mx52nv
Purple Porsche Eater
Postby mx52nv » Fri Apr 16, 2010 2:32 am
SAE75W/90 Gear oil - most of the WA crowd uses Redline Shockproof.
You will need 1 liter or 1.06 quartz (two bottles) for a NA8/NB8 diff.
I suspect the NC will require a little more.
Les
Charlie Brown
Postby Charlie Brown » Fri Apr 16, 2010 9:56 am
mx52nv wrote:SAE75W/90 Gear oil - most of the WA crowd uses Redline Shockproof.
Les
The NC is actually less. 0.7 litres GL-5 90 for the diff. Gearbox is 2.1 litres GL-4 75W 90.
rascal
Postby rascal » Fri Apr 16, 2010 9:58 am
I use Penrite Sin 80 (80W-140) in my Mazdaspeed 1.5?way.
Changed it after the first track day break-in and its been excellent (quiet, no chatter) ever since..
Locutus
Postby Locutus » Fri Apr 16, 2010 10:33 am
i'm surprised all oils mentioned so far are not labelled LSD compatible by their manufacturers.
i'm in the same situation and am currently eyeing motul 90PA.
wun911
Postby wun911 » Fri Apr 16, 2010 5:43 pm
Hrmz kazz make their own LSD diff oil I was thinking of bying a tin of that.
Can you use the same oil that you use for the gear box MT90?
every ounce counts
mx52nv
Postby mx52nv » Fri Apr 16, 2010 6:48 pm
Cusco LSD Oil Group Buy? :mrgreen:
Les @ MX5 Shop
wun911
Postby wun911 » Sat Apr 17, 2010 12:10 am
Sorry I'm not really willing to wait for another GB.
I think you can get it locally, around 60 dollars for a 1 L tin.
every ounce counts
Hellmun
Postby Hellmun » Sun Apr 18, 2010 5:32 pm
Locutus wrote:i'm surprised all oils mentioned so far are not labelled LSD compatible by their manufacturers.
I called Hi-Octane in Sydney when I got the Tomei Diff as they're the australian distributor. He said they run the Royal Purple Max gear with all their cars. They've made a few weapons so figured they were a good source. The Royal purple lasted 30,000km but then it's tracked non-stop. So I probaly should've changed it earlier...
deviant
Postby deviant » Mon Apr 19, 2010 9:06 pm
My NA8 has got an unknown LSD in it. Low speed / tight maneuvering is hard work with juddering and all sorts of funny noises so its definitely an aftermarket one of some sort.
I have got in my shed an unopened bottle of Limslip 90 Extra heavy duty SAE 80W90, API GL-5/6. Would this be okay to use?
fattima
Postby fattima » Mon Apr 19, 2010 9:14 pm
Are you sure it is an LSD? Could be a locked diff by the sound of it.
I used to run Limslip in my plate type diff of my Escort with no probs.
deviant
Postby deviant » Mon Apr 19, 2010 9:22 pm
I don't think it is locked. I have not really had a chance to 'make progress' properly but it feels like my old Mk1 MR2 did with a harsh KAAZ clutch type LSD...behaved like a locked diff at low speed but felt normal on the move.
I just want the thing to be a bit quieter and less juddery. I'm thinking part of the problem may be that it has not been done in a long time!
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Apr 22, 2010 12:59 pm
that limslip 90 sounds fine. those are the same oil specs that kaaz recommend too.
i just bought some nulon lsd oil which has simlar specs to those.
http://www.nulon.com.au/products/SAE_90 ... ntial_Oil/
