THE Man Purse >> not 56k friendly.
Shinigami!
Postby Shinigami! » Fri Apr 16, 2010 12:11 pm
The Man Purse:
Purchased late November 2009 after I sold off my old drift car for something more street suitable/fun I guess.
White 1990 NA6: 85rwkw
So the plans were to build a nice tough little car capable of doing mountain runs and maybe some sideways action. Unfortunately is a short nose motor so I’m basically just waiting for it to go despite that I do regular checks to make sure the pulley is in good order aka not going to fall off on me midst driving.
I know that I can tuck 15 x 8 +0 under standard guards but that involves lower/defectable ride height. I did however managed to bash the guards out so only just 10-15mm sticks out but that is still defectable despite being just over 100mm off the ground from the chassis rails, so I don’t mind that the wheels stick in like 10mm with flares on. Might run 205 or 215/50tires to compensate as I’m running 195/50 all round. I want a bit more power so I’m prioritizing that at the moment as I like how it handles so far. I want around 90+ rwkw. The itb have caused noticable lose of botton end torque, and sometimes it's a sh*t of a thing to drive sometimes but the induction noise is worth it =D
So this is what I’ve done to it so far:
- TODA Racing Aggressive Camshafts both intake and exhaust.
- CBR ITB mated to standard intake manifold
- 2.5 inch cat back exhaust from the states. Looks like a greddy knock off? Still rocking the stand headers/front pipe and cat
- EMS Stinger tuned via tps not map vacuum.
- Walbro in tank fuel pump
- GReddy oil catch can
- Aftermarket Fuel Regulator (removing the stock fuel reg and putting a fitting in instead)
- 15x8 +0 Work Equip Copies
- Modified Flares
- Garage Vary Lip
- 3inch Yellow Fog Lights
- HKS 60mm Water Temp
- 76 Lubricant Rear View Mirror
- Have a fixed back seat with rail lying in my room as my gaming chair >> don’t want to get defected. Its blue and stands right out.
- Mazdaspeed 4 point Roll Bar >> padded and plated
- Some crappy steering wheel with quick release. Couldn’t run my White lollypop one >> =[
- BC // BR Coilovers
- Trust white plastic shift knob >> my old dildo one snapped.
- And various vinyl all over my boot >> which I plan on keeping even if I sell this car.
- Thermo fans are hooked onto a switch so I have complete control over them
Things for the future so far;
- OBX ceramic coated headers 4-2-1
- Camshaft gears
- Alloy radiator if I need it and possible a thermostat which opens earlier
- Once the engine goes;
o 11.1 high compression pistons
o Forged rods
o Stiffer valve springs
o Some porting/polishing
o Slight shave of the head to increase compression that little bit more
- 1.5 LSD possibly from Japan
- Shorter Diff pinion/gear from rs asiwa >> 4.7 (maybe)
- Better clutch/lighter flywheel
Enough talk, now onto the pictures >>
Heres a picture of my old car in action;
This bar died on its first outing but nothing an odd 50-100 zipties can’t fix.
Heres a picture of when I first got it home. Mighty gay;
And here is how it sits right now;
Postby sliq » Fri Apr 16, 2010 12:41 pm
i sorta like it cos its so ding and dented :D
de Bounce
Postby de Bounce » Fri Apr 16, 2010 9:14 pm
Love the piece of wood and strapping holding the throttle cable in place.
Got that 'There I Fixed It' look :mrgreen:
Motorkhana Video
Shinigami!
Postby Shinigami! » Sat Apr 17, 2010 1:03 am
indeed the there i fixed it look was involved haha, its not permanent but yeah.
the throttle cable mount would flex on full throttle so a piece of wood is light and will do the job for now haha.
SuperMazdaKart
Postby SuperMazdaKart » Sat Apr 17, 2010 7:01 pm
Oh, it's got a decal of the K-On girls. Someones a fan of anime.
Shinigami!
Postby Shinigami! » Sat Apr 17, 2010 7:07 pm
yes i am. :D
being asian its quite normal/more accepted lol.
SuperMazdaKart
Postby SuperMazdaKart » Sat Apr 17, 2010 7:16 pm
Yes I know. I'm an anime fan myself too. Do the cosplay thing as well at conventions.
I had wanted to get a large sticker of Ayame from the Tenchu Stealth Assasin game to put on my GTR as I had named it Tenchu. Might happen one day :)
red63sprint
Re: THE Man Purse >> not 56k friendly.
Postby red63sprint » Sun Jun 20, 2010 9:52 pm
This will be my screen saver from now on...
1993 Clubman, Mx5plus roll bar
Autotechnica seats, Revalved Bilsteins
Fatcat Motorsport adjustable suspension
Espilier springs, Whiteline front bar.
wazman
Postby wazman » Sun Jun 20, 2010 11:34 pm
Love the rear view mirror! I just watched the episode of "Initial D -forth stage" with the mx5 downhill battle...... your car reminds me of that! Those bolt on flares are not ment for mx5 are they? .....
ilovedrift.com
BadBong
Postby BadBong » Mon Jun 21, 2010 12:53 am
They don;t look like flares... looks like he bashed the guards out and it just happened to looks 'flarey'.
CoffeeBoss
suntory
Postby CoffeeBoss » Tue Jul 06, 2010 6:17 pm
I like the title of this thread.
Particularly when you start filling your Roadster with your worldly possessions, it being an extension of the body and all... this one is quite the accessory :D
Nocturnal
Postby Nocturnal » Mon Jul 12, 2010 1:35 pm
If you spray paint the top of the gauge cluster black it's barely noticeable compared to the white.
Doesn't "stand out".
Shinigami!
Postby Shinigami! » Wed Sep 01, 2010 7:16 pm
gauge cluster is actually broken and removed haha. its more fragile than you would think.
just a little update i guess:
1/ i am still alive believe it or not.
2/ i have replaced the exhaust with the stock exhaust so now i can definitely hear the itbs
2/ removed the flares so now the 15x8 +0 do some poking and i've lowered in a little bit.
tuned_to_fly
Postby tuned_to_fly » Wed Sep 01, 2010 8:19 pm
Community Channel quote is cool :mrgreen:
Shinigami!
Postby Shinigami! » Fri Sep 03, 2010 1:01 pm
