Short Antenna
- sliq
Short Antenna
Hi all,
I have been looking for a replacement for my electrical antennae.
I want to have it replaced with a short stubby one, as seen here:
http://www.mx5parts.co.uk/product_info. ... ts_id/1646
But this kit can't be fitted to electrical antennaes.
Has anyone out there successfully fitted this in? Did you also replace your aerial base with one of these?
http://www.mx5parts.co.uk/product_info. ... ts_id/1405
Any help would be much appreciated
- Benny
Short Antenna
I don't know for sure, but it could be that the electric antennas we have, have the coax cable permanently wired into the antenna, and so you would have to cut it and re-terminate it with the correct plug, or run another coax from the radio to the antenna.
I doubt the length of the antenna below the guard would be too long to fit as these types of antennas usually have a very short base.
It could also be that the hole in the guard for the electric antenna is too large.
Personally, having a screw in and out antenna would worry me, becuase there would be times I would forget to take it off, only to find it missing or broken by the time I got back.
Short Antenna
i kinda like the short rubber ones without the motor that drives it up and down
any sort of gb on the horizon??
every ounce counts
- Benny
Short Antenna
A good friend of mine owns and antenna company called Mobile 1.
I'm sure he could make us a custom made antenna for our 5's.
He made us a whole lot of rubber duckies with magnetic bases for the old AM radios we used to use for club runs and they worked very well.
Far better than the UHF radios that they use now that can't even get from the front of the pack to the last car in the group.
- ll_spud
Short Antenna
Hey, I'm interested if you can organise a GB or find a source somewhere.
Not a fan of the OEM long retractable antennas. Looks really oldschool.
I've seen them on the NA's. Just dont know where to get them.
- philz
- Wheel guru
Short Antenna
s2000 ones might work
- Steampunk
Short Antenna
I wouldn't mind a "shark-fin" type
- TieNN89
Short Antenna
Benny wrote:I don't know for sure, but it could be that the electric antennas we have, have the coax cable permanently wired into the antenna, and so you would have to cut it and re-terminate it with the correct plug, or run another coax from the radio to the antenna.
There is a plug that plugs into the side of the electric antenna
Its just a standard antenna plug that you find in most jap cars
With the manual base + stubby aerial kit I don't see why it wouldn't work
- sliq
Short Antenna
tien's spot on.
i bought the manual base with a stubby antenna for mx5's.
will let you guys know how it goes when it comes in. i'll do a write up if i can.
- TieNN89
Short Antenna
sliq wrote:tien's spot on.
easy as
if your look at the antenna base you have on your car at the moment
the chrome base is like a nut, if you turn that anti clockwise
there is also a nut/bolt behind the boot trims as well can't exactly remember
If you have trouble give me a yell
- sliq
- TieNN89
Short Antenna
sliq wrote:have you done this mod already? pics?
haha yeah something like that
Not the same antenna though
But I have since gone back to stock
I much prefer the antenna not there at all (only when the radio is not used)
- sliq
Short Antenna
how did you find the reception on the shorter antenna?
- TieNN89
Short Antenna
sliq wrote:how did you find the reception on the shorter antenna?
Still pretty good
Mine was the S2000 a like one I'm pretty sure
Where the antenna angles back like 45 degrees
I might find it and put it up for sale
Users browsing this forum: No registered users and 255 guests
