avo instal
- wazman
avo instal
on the avo instructions they also pressurize the motor with compressed air so as the drill starts to penetrate into the sump the shaving get blown out away from the hole, i used this method, very effective. I just wrapped a rag around the air gun and got some one to blow it into the oil cap hole as i drilled.
ilovedrift.com
avo instal
Hi guys,
Actually im bolting on the turbo myself at the moment...
Come to a little hiccup on how to bolt on and mount the intercooler... The brackets that AVO gave me are not even matching with the body of the car and having some serious problems.
Does anyone know what to do or where i can go so the net can help me?
avo instal
it should bolt up fine
the bracket thingo on the lhs i think goes up bolts up and hangs on from under the bonnet catch
and the other one bolts up to the body which i think i had to drill the existing hole out to fit the bolt
leave the gun.... take the canoli's
avo instal
We did do it finally.
However it doesnt have any brakets to bolt on under the bonnet.
I did some customized bracketing.
Thanks for your help though.
Engine should be going in tomorrow and then do all the intercooler piping.
avo instal
Good stuff - nearly there!
avo instal
wazman wrote:on the avo instructions they also pressurize the motor with compressed air so as the drill starts to penetrate into the sump the shaving get blown out away from the hole, i used this method, very effective. I just wrapped a rag around the air gun and got some one to blow it into the oil cap hole as i drilled.
Magnets work really well for this too.
I had to remove a snapped fuel-rail bolt from the engine block using Easy-Outs and I was worried about iron filings getting inside the engine block (and all over the place). I had a couple of old computer hard drives around so I pulled them apart and grabbed their magnets - these are incredibly powerful. I stuck them either side of the broken bolt and reverse-drilled slowly. It's surprising the amount of iron filings created by drilling with just a drill bit, let alone the Easy-Out. I'm betting the magnets caught every iron filing.
avo instal
Get a turbo!!!
Just some words of advice....There's no such thing as a "BOLT ON" turbo, as I have learnt this weekend hahaha
avo instal
petross wrote:Hi guys,
You're kidding? Mine fitted perfectly and it wasn't even for my shape (NB kit on NA)
avo instal
Adam_NAclubman wrote:petross wrote:Hi guys,
No joke.
Had to get brackets from Bunnings, bend them and all sorts of things. Did that and the intercooler is firmly stable.
Isnt going anywhere!
avo instal
Are you sure you were trying to mount it in the right spot? From memory the tabs on my cooler lined up to the captive nuts in the body, and the NB piping kit lined up perfectly on my NA
avo instal
Yeh pretty sure.
The AVO instructions were absolutely terrible as well...
Anyway its on now and running
Users browsing this forum: No registered users and 92 guests
