http://s490.photobucket.com/albums/rr26 ... =slideshow
Details:
I wanted to install an amplifier to get the most out of my JL Audio ZR650-CSi door speakers. Since I intend to get a roll bar installed, and the rear speakers in an SE are virtually useless anyway, I decided to go for a 2-channel amplifier.
I didn't want to lose any bootspace so needed an amp that I could mount in the driver's side tunnel, next to the fuel tank. The JVC KS-AX3002 amplifier looked like it would fit, here are its specs:
* Max. Power Output of 370W
* Continuous Power Output (RMS): 65W x 2 at 4 ohms, 90W x 2 at 2 ohms, 130W x 1 at 4 ohms bridged
* 2- or 1-Channel Operation
* Class-AB Circuit
* PWM Regulated MOS-FET Power Supply
* Frequency Response: 5Hz - 50000Hz (0, -3dB)
* S/N: 76dBA
* THD: Less than 0.04% at 1kHz
* HPF (150Hz, -12dB/oct)
* LPF (80Hz, -12dB/oct)
* Variable Input Level Control (0.3 - 6V)
* Gold-Plated Input Terminals (Power)
* Gold-Plated RCA Jacks
* Speaker Input Connector
* Protection Circuitry (Thernmal/Short Circuit/Overload/DC Offset)
* Anti-Pop Circuit
* LED Indicator
* Width 13.1 in
* Depth 8.3 in
* Height 2 in
I also bought an amplifier wiring kit but decided to use a shorter RCA cable that I had since I only needed a 2.5m cable and the kit's RCA cable was 6m.
I intended to mount the amplifier longways but with the wiring installed, it was not going to fit without stressing the connections. Luckily for me, it was possible to mount it sideways but was going to be a tight fit.
There is an OEM hose and brace that prevented the amplifer sitting flat so I got aroud this by using 2 MDF mounting boards and cutting a corner "notch" out of the lower board to prevent crimping the OEM hose and clear the OEM brace.
There are three nuts on the driver's side chassis - I needed to cut a notch in the MDF mounting boards for the front notch to allow them to fit. This notch has the benefit of keeping the amplifier from sliding back and forward too.
I glued a rubber mat on the bottom MDF board to absorb vibration and help prevent it from sliding.
The amplifier is now wedged in tightly and the amplifier does not contact the chassis at all.
The door speaker wiring was a bit of a hack since the NB uses a harness to connect the door speakers rather than just passing the speaker wires through a door loom. Some guys simply wire their speakers to the existing harness at the Head Unit but I didn't want to go from 16 gauge wire to whatever the lower-specced OEM wiring is and it's hard enough as it is fitting my Pioneer FH-P80BT in as it is. I didn't want to drill new holes into the chassis so passed the wires through a gap in the door stop and they fit between the door trim. I made sure that the speaker wire was not crimped when the door was closed and that it remains contained behind the door waterproofing rubber.
The speaker wire was routed under the trim behind the driver and passenger side respectively and under the door trim. The passenger's side has a plastic hose that was "empty" so I threaded the wire through it. The driver's side has a wiring loom that I thought I'd use. After cutting the tape along it to fit the speaker wire into it, I found it almost impossible to insert the speaker wire along its full length so removed it, retaped the loom, and wired the speaker cable underneath it.
After the install, I fired up the stereo and got NOTHING!!!
I immediately googled amplifier install problems and figured that it MUST be a grounding issue so pulled everything apart and tested all fuses and wiring. NADA!
Next I hooked up a portable radio to the amplifier and everything worked perfectly?
I reconnected the Head Unit and tried to see if there was a menu setting to force it to use the RCA output instead of the harness output but found nothing. The manual didn't mention anything about this either.
I then figured that there must be a hardware switch on the head unit to force it use RCA output so pulled it out and found nothing! The manual didn't mention anything about this either.
Since the Head Unit was out, I hooked the portable radio up to the RCA connectors and heard NOTHING!
I then hooked the amplifier wiring kit's RCA cable up to the Head Unit and amplifier and everything worked perfectly!
It was that damn, F*****G RCA "lying around" cable that was problem, which is probably why it was spare in the first place!
I bought an overpriced 3m RCA cable from "Hardly Normal" since they were the only ones I could find who sold RCA cables approximately 2.5M long, and fitted it.
So was it all worth it?
HELL YEAH!
The output of my 6.5" crossovers really blew me away when I first heard them in the car. The car really pumps now and there's no need for a subwoofer since the doors really thump now with medium volume levels. I took the car on a trip to Mt Nebo and Mt Glorious on Saturday, then some highway driving, all with the top down, and the sound was fantastic where previously it would have gotten drowned out.
