MX5 crankshaft differences - are there any?
NMX516
Postby NMX516 » Tue Mar 09, 2010 8:22 pm
Hi folks,
Can anyone confirm for me whether the crank in an NB8B would be the same as in NB8A's or even NA8's?
Thanks in advance :)
Postby orx626 » Tue Mar 09, 2010 9:37 pm
Hi Gerard, I just checked and the part number is the same...just revised once...went from BP06-11-300C to BP06-11-300D. :D So they are interchangeable.
So all is good! See you in the morning.
NMX516
Postby NMX516 » Tue Mar 09, 2010 9:54 pm
Good news! Thanks Danny.
It will be late morning before I can get there, but will see you then.
Postby manga_blue » Fri Mar 12, 2010 9:07 am
I put an NB8B crank, pulley boss and rods straight into an NA8 block. The cranks appear to be identical but there was a rumour somewhere that the NB8B wwas a better metal.
NMX516
Postby NMX516 » Fri Mar 12, 2010 7:09 pm
hmm, thanks manga_blue. Interesting that the metals could be different.
Postby manga_blue » Fri Mar 12, 2010 8:10 pm
Yh, don't quote me on that. It was a metallurgy thing ... something about the higher compression or power in the NB8B demanding better heat treatment in the bottom end.
NMX516
Postby NMX516 » Fri Mar 12, 2010 10:47 pm
Oh well that's not too bad then, I could always get an earlier one nitrided or tuftrided depending on the metal used if necessary. Might do that anyway, no harm in increasing the strength of a crank.
Postby manga_blue » Sat Mar 13, 2010 12:33 pm
NMX516 wrote:Oh well that's not too bad then, I could always get an earlier one nitrided or tuftrided depending on the metal used if necessary. Might do that anyway, no harm in increasing the strength of a crank.
I asked about that too and got the answer that the rods break long before the crank does. I ended up getting all mine balanced as a set, i.e. standard crank, pulleys, rods, pistons, flywheel and clutch housing. It's only an N/A NA8 motor pushing out about 78rwkw. After losing 5th gear I was holding it on a 7,500 redline in 4th for 17 secs up PI's main straight over about 50 laps with no problems.
