need help! im fitting new rotors and pads and having trouble
mxfive95
Postby mxfive95 » Fri Mar 12, 2010 8:04 pm
G'day,
I have fitted the fronts with out any problems but im now having trouble with the rears... :roll:
The old pads and rotors are off but i cant compress the calipers to put the new pads on. The hand brake is off but still attached and the brake line has been taken off.
Any help would be greatly appretiated as i need my car for sunday on the reefton run.
Thanks in advance
Craig
The bumper sticker on my porsche
"My other car is an mx5"
Postby manga_blue » Fri Mar 12, 2010 8:27 pm
Look under the rubber cap. The allen key is your friend.
de Bounce
Postby de Bounce » Fri Mar 12, 2010 9:12 pm
The web is a wonderful resource - if you are prepared to do a search
You will find the information you seek HERE or HERE
Motorkhana Video
mxfive95
Postby mxfive95 » Fri Mar 12, 2010 9:17 pm
manga_blue wrote:Look under the rubber cap. The allen key is your friend.
Awesome il give it a try thanks for that.
I tell you old cars are a nightmare... i had to heat up the old rotors with an oxy to get them off :lol:
mxfive95
Postby mxfive95 » Fri Mar 12, 2010 9:56 pm
great i found the allen key screew (it was hidden behind a metal bolt)
Now i need a rear left brake caliper as the guide bolts didn't have the rubber dust covers on them and rusted up :lol: James at MX5 Centre should have one :D
mxfive95
Postby mxfive95 » Fri Mar 12, 2010 10:04 pm
de Bounce wrote:The web is a wonderful resource - if you are prepared to do a search
Thanks for the search, my internet is pretty slow so i got impatient searching... next time i think il search before i start :D
Guran
Vehicle: ND - 1.5
Postby Guran » Fri Mar 12, 2010 10:47 pm
This is a very familiar story. Had the same experience myself when I first got my NA6 and first job was changing the brake pads - those rear pistons are tricky. I ended up here after a Google search. :D And the rear pad change went very smoothly after that. I highly recommend you invest in an MX-5 Workshop Manual if you plan on doing your own maintenance. I've been very hapy with my "Rod's" manual.
