Horn not horning...what could it be?
mitch_f1
Postby mitch_f1 » Tue Mar 09, 2010 9:26 pm
So I recently tried to remove my steering wheel to replace it, but it would not budge, so I gave up. Since then my horn button is not working. I took the horn button off, and and took it apart, everything seems to be fine with no corrosion or anything. What could it be?
7Hazi
Postby 7Hazi » Tue Mar 09, 2010 9:39 pm
I had the same problem on my NA8 (horn not going off when I push the button) except, in addition, my horn would just go off randomly when the car was parked... for example, at 6 in the morning when I'm trying to sleep :lol: . Check the connections to the horn and the wires around it (behind the front bar). Upon doing thing I found mine weren't connected properly and the insulation on the wires was falling off.
mitch_f1
Postby mitch_f1 » Tue Mar 09, 2010 9:49 pm
nup, no fix. I had a similar issue a little while back while trying to perform the same opperation, and it was fixed by a little jiggle of the horn button while in the steering wheel? I'm thinking it might be in the boss???
RG.net
Postby RG.net » Wed Mar 10, 2010 1:18 pm
How is the ground wire connected?
Grab a piece of wire, connect it to the horn button and touch the inside of the boss (exposed metal), then press the horn button. if that works then the current ground connection is loose.
Postby Lokiel » Wed Mar 10, 2010 2:00 pm
Have you checked the 15A fuse under the hood?
mitch_f1
Postby mitch_f1 » Wed Mar 10, 2010 2:04 pm
tried, and nope
15A fuse intact
Postby bruce » Wed Mar 10, 2010 2:18 pm
In the NA, there's another fuse under the dash next to the drivers footwell. You have to be a contortionist to get to it.
mitch_f1
Postby mitch_f1 » Wed Mar 10, 2010 2:21 pm
Mine is all in Japanese, do you know which one it is specifically?
Just took them all out, and they looked fine. But maybe if i replace just the horn one there is a fault that I can't see in it??? (fingers crossed)
Postby bruce » Wed Mar 10, 2010 2:41 pm
Can't remember which one it is (I used the guide on the lid, but yours is in Japanese).
mitch_f1
Postby mitch_f1 » Wed Mar 10, 2010 2:46 pm
Could someone do me a huge favour and find out which one it is on their NA6. I have the workshop manual but can't make out the one for horn
mitch_f1
Postby mitch_f1 » Wed Mar 10, 2010 2:57 pm
That is what mine looks like
Postby 93_Clubman » Wed Mar 10, 2010 3:33 pm
just checked mine (na8), which has the same amp fuses in exactly the same positions, but none of them are marked 'horn', however na8 owner's handbook states that the 'stop' fuse also is for the horn. 'stop' fuse is the middle 10 amp fuse, i.e. the 10 amp fuse marked 10A above the 'H' in '(FB200102H)' in your pic.
mitch_f1
Postby mitch_f1 » Wed Mar 10, 2010 7:36 pm
BUGGGEERRRR
So changed out that fuse, and nothing. Thanks for you help btw clubman
Guran
Vehicle: ND - 1.5
Postby Guran » Wed Mar 10, 2010 8:07 pm
Are you able to disconnect the horn itself? If so, you could try connecting it directly to a spare car battery to see if it still works. If it does, then you must have a bad connection somewhere along the way. Some checks with a multimeter would resolve it fairly quickly.
mitch_f1
Postby mitch_f1 » Sun Mar 14, 2010 6:29 pm
okay so i am in the process of taking apart the steering column, but i cant follow the horn wire past the metal disc with the spring thing on it. Any idea on which plug, maybe even cable colour it comes out of?
