silvermiata wrote:getting ideas from the forum is always good, but it will just make you more and more confused IMO, take it to mechanic that knows mx5, and get them to have a look at it.. it could be cheaper because you might keep changing various sensors/parts which costs $$.. just my 2c..
i was thinking of taking it down to mania, but just wanted the satisfaction of fixing it myself, even tho it probably has costed me more in petrol when the car runs rich (12L/100kms)
Dweezle wrote:Yeah mate..
I have the old sensor still if you want to give it a try??
Just let us know, you can pick it up whenever you want if you wanna give it a go??
Sweet, i'll give you a buzz on sat if im in the area
93_Clubman wrote:Have you recently, or at any time disconnected the battery & depressed the brake pedal a few times for 5 or so seconds a time to clear/ reset the ECU?
The battery has been disconnected in the past, but i never knew to pump the brake pedal. In saying that, when the battery was diconnected, the ecu error did clear but eventually came back
