Best Fuel to use
JBT
Best Fuel to use
Postby JBT » Thu Mar 04, 2010 9:19 pm
The NA engines (1600 & 1800) were designed to run on 91 RON. E10 is not recommended.
Best Fuel to use
Postby Hammer » Thu Mar 04, 2010 9:28 pm
You'll find there has been a lot of discussion about this topic in this forum if you do a search. But as a general consensus, most people here use 98 octane fuel like, V-Power and Optimax.
Best Fuel to use
Postby manga_blue » Thu Mar 04, 2010 10:15 pm
91 or 95 will work fine if you're just running standard timing and compression. Most people here do the 14deg timing bump for a bit more low range power. If you do that then it helps to use 95 RON or, in some caes, 98 RON.
Mods? The first mod is always a good wheel alignment. The second is good tyres. Everything after that is optional, more expensive and less benefit. :D
WASP
Best Fuel to use
Postby WASP » Fri Mar 05, 2010 7:43 am
Hi When you start modifying you will never stop, trust me
