Where does your temp gage sit??? NB
- JBT
The temp gauge is an "idiot" gauge in that it indicates cold when it's cold, about half way when in the "normal" temp range (don't know how wide that range is) and then hot when it's bloody hot.
Not sure if the NB ECU and temp gauge have the same sensor. However, if they do and if that sensor was replaced to rectify your mis-firing problem, maybe it's a suspect sensor.
from what I have seen halfway is the way these guages are set to read. You could have an overheating prob
- MINX
Mine sits on the high side of half way.
My Scan Gauge http://www.scangauge.com.au/features/index.html
shows that the Idiot Gauge shows 'normal' from about 75 degrees to the real normal of 90 degrees.
Mine sits dead centre.
however my car spews coolant, so mine might not be the best judge
- two40
A touch over half way for me.
Later model landrovers have the same deal.
Temp guage indicates; Cold
Warm up
Operating temp
Oh S..t
Warm up
Operating temp
Oh S..t
Jish
There was also a thread regarding CAM sensors with similiar misfire and cut out symptoms I think .
Would it be possible to check the real temp or block /head temp with an infrared thermometer
Pete
Pete
- timk
G'day all,
My temerature gauge has always sat at about "normal". However - the other day when I was driving through Sydney the car cut out because of overheating while the temp gauge was still at normal I let it cool down for a while then started off again. This time the temperature gauge went all the way to very hot and the car cut out again. Luckily, no major damage other than a radiator top tank needing replacement. Since the repair - a $700 job - the gauge still sits on normal all the time.
I don't trust the gauge and will be installing a more accurate gauge in the near future.
It is good to see that the ECU will actually cut out the engine if it gets too hot. Thank goodness because I could have had a cooked engine otherwise.
- tuned_to_fly
Mine sits to the left of 12 o'clock also.
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
djw24s wrote:G'day all,
$700 ???!!!???!!!
I'm sorry to ask the obvious, but you do realise that for less than $400 you could have had a whole new radiator? I had the top tank replaced on my old radiator a few years ago and it cost me $200.
- Patty
Unfortunately the same thing happened to me two weeks ago. Came to a set of lights to have it splutter and stall. Temp gauge was in it's usual 12 o'clock spot. It wasn't until a few minutes after I pulled over when it shot past the hot side.
Turns out I had a leak halfway down the radiator core. But yeah $700 is ridiculous. New radiator = $390 landed. New coolant + demin water + radiator flush ~ $75ish. Didn't change hoses though, they felt ok.
Edit: whoops i meant $290 landed.
Grace Green NB8A
labour costs at least $75 per hour so even $400 for a radiator crank up to $500 in a blink. The issue for radiators or any other major component is its quality. When you buy a radiator if it comes from one of the major OE makers eg Calsonic you can be fairly sure that it actually passes through a stringent quality system which sets out to produce an item with no defects and soundly engineered. What is the average life of an OE radiator?
