Im considering getting a radiator cowl cover for my NB8B...
Are they worth it? Or are they really just a bit of engine bay bling?
Thanks
Josh
SuperMazdaKart wrote:Only difference I noticed with my NA6 that I added one to was that the A/C worked better
Fatty wrote:SuperMazdaKart wrote:Only difference I noticed with my NA6 that I added one to was that the A/C worked better
which proves that the air is now flowing through the condensor (and thus, also the radiator), rather than up and over the top of it.
they are a good thing.
did you have the factory plastic cover before you had one fitted (assuming that you upgraded to one of the metal versions)?SuperMazdaKart wrote:Only difference I noticed with my NA6 that I added one to was that the A/C worked better
correct me if i'm wrong, but the seal actually runs along the bottom of the front edge of the bonnet. the cowl cover is to prevent air passing through the 'mouth' in the front bar, then going up and over the radiator rather than through it.olboy wrote:I might be wrong but I think the seal under the bonnet keeps the air from going up and over
1red5 wrote:Might be a moot point anyways as I haven't seen an aftermarket cover made for NB's. Happy to be corrected.
