hey guys , i bought a NA6 and on idle it seems abit shakey .. like it goes fine then shakey shakey then fine , shakey shakey .. motor still runs strong tho, could it be the timing belt ?
is it cause engine mounts are old or signs of crank nose problem ?
any help would be appreciated.
cheers
MAZDA NA6 engine , shakey on idle is this normal ?
- Learner Driver
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
This is kind of like phoning your doctor and telling him you have a spot - and asking what it could be
If the motor runs strong through the rev range it is unlikely to be the crank issue I'd say.
Engine mounts - a good starting point.
Best thing is to visit your doctor - I mean MX5 mechanic.
- jerrah
What RPM is the idle speed at? If the idle speed is low it will be a bit rough.
1991 MX5
- Learner Driver
idle seems to be kind of normal , around 900rpm? i think cant remember ..
- Learner Driver
can anyone else help ?
cheers
cheers
- jerrah
I would suggest getting a mechanic to look at it. If you adjust up the idle to around 1000rpm does it keep doing it?
1991 MX5
- Learner Driver
hey man , where abouts is the idle screw ? ill give it ago .. can someone explain where it is ?
cheers
cheers
Me, me, me!
Spark plug leads?
Spark plug leads?
buy a Haynes manual- small investment for a reference source. When were the plugs last changed etc ?
- Learner Driver
car just had a service , with new iridium plugs , so what abts is the idle screw around i can just find it ?
- bensale
Its not the plugs that can be a issue, rather the plug leads...
It sounds to me like you have the classic idle droop problem where the manual idle speed is set too low.
The manual idle control is located on the top of the throttle body. You'll need to bridge the 10 and gnd terminals in the engine diagnostics box to put the car in manual idle speed mode rather than ECU controlled idle. You then adjust the manual idle via the screw and match it to the ECU idle by unplugging the briding wire in the diagonstics box. when the idle doesn't change irrespective of it being bridged or not you've got it right.
Make sure the car is warmed up properly when you do this otherwise you'll cause it to idle ever worse and possibly stall.
www.othersideproductions.com
Users browsing this forum: No registered users and 217 guests
