Variable TPS for 1.6l
1.6lAutorotor
Postby 1.6lAutorotor » Mon Feb 15, 2010 4:54 pm
Hi All,
The variable TPS part number listed in searches to replace the 1.6l on off TPS no longer finds a part.
BMW/Bosch automatic TPS (part number 0280120402) including plug/tail.
What i have found is another part BMW/Bosch TPS #0280120406 is still availble +$200 :( but am not sure if it will fit, or if it is variable?
What have other people done when adding after-market ECU's, or should I be ringing wreckers and not new (repco). The car is waiting for this one part.
jerrah
Postby jerrah » Mon Feb 15, 2010 9:34 pm
Alternatively you could try the NB6 manifold and NA8 throttle body. I'm going through that currently myself.
1991 MX5
1.6lAutorotor
Postby 1.6lAutorotor » Mon Feb 15, 2010 10:13 pm
Thanks for the reply
The throttle body is mounted to the front of a supercharger so I won't need the manifold. Are there any complete throttle bodies that have the same bolt pattern, will an auto model na6 fit? Or should I just get an na8 and change the mounting pattern?
I'll have to ring some Mazda wreckers tomorrow. I want my car back.
jerrah
Postby jerrah » Mon Feb 15, 2010 11:00 pm
Auto NA6 would fit but I'd imagine it'd be extremely rare.
1991 MX5
Postby 93_Clubman » Tue Feb 16, 2010 12:29 pm
SuperMazdaKart
Postby SuperMazdaKart » Tue Feb 16, 2010 6:31 pm
After a standard TPS for 1.6?
I threw out a 1.6 throttle body with the TPS attached into the bin today....
1.6lAutorotor
Postby 1.6lAutorotor » Tue Feb 16, 2010 8:02 pm
Thanks for the offer, but it's about 3 hours too late. The guys at the mx5centre had one and were kind enough to drop it at the mechanics. So I should get the car back tomorrow.
Thanks everybody for the sugestions
