Big Brake Kit
WASP
Big Brake Kit
Postby WASP » Fri Feb 12, 2010 10:22 am
Hi I have fitted a big brake kit to my 1994 NA.The std 14 inch space saver wheel does not fit over the calipers,15 x 7 inch wheels.Are all MX5 space savers 14inch and does anyone have any "polite" suggestions
WASP
Big Brake Kit
Postby bruce » Fri Feb 12, 2010 10:39 am
I don't think any spacesaver will fit over non-standard brakes. You might have to make do with a can of tyre goo.
Big Brake Kit
Postby 93_Clubman » Fri Feb 12, 2010 11:30 am
WASP wrote:Are all MX5 space savers 14inch
The NB space saver is larger than the NA space saver, but I'm not sure if the NB8B space saver is larger than the NB8A space saver given the increase from 15" to 16" rims on the later model. However, you might find the NB8A space saver is sufficiently large enough for your situation.
wun911
Big Brake Kit
Postby wun911 » Sat Feb 13, 2010 5:09 pm
Looks like flyin miata one...
every ounce counts
