Heatshield
SuperMazdaKart
Heatshield
Postby SuperMazdaKart » Sat Jan 30, 2010 9:36 pm
"Cool" heh.
Fair way out for the oil filter though. I got the same JetCo shielded air filter too :)
rossint
Heatshield
Postby rossint » Sat Jan 30, 2010 11:41 pm
Yea, wanted the filter over the other side but no room for it with out moving some stuff about. It will eventually go to an oil cooler.
wun911
Heatshield
Postby wun911 » Mon Feb 01, 2010 12:41 am
did you paint the cam cover blue or is that anodized
if its anodized where did you get it done (weigh less than paint i hear)
every ounce counts
rossint
Heatshield
Postby rossint » Mon Feb 01, 2010 12:59 am
Painted by the guy who owned it before me.
rrrossco
Heatshield
Postby rrrossco » Fri Feb 12, 2010 11:02 am
Looks good and it is available at my local S/cheap, will it curve more or did you just want a straight kind of look when fitted? I was thinking it might look ok with a rolled effect as well.
rossint
Heatshield
Postby rossint » Fri Feb 12, 2010 1:09 pm
It can be shaped into just about anything you care to throw at it, look at the pic in the link:
http://www.aclperformance.com.au/prod_heatshield.htm
I just went for quick and easy.
Heatshield
Postby manga_blue » Sun Feb 14, 2010 10:28 pm
MG Garage on ebay was the best way I found to buy it. They were good.
My extractors run fairly close to the firewall, all the heat issues I had were with wiring and ecu frying on the cabin side. A sheet of this rolled to fit between the pipes and the firewall finally fixed it.
rossint
Heatshield
Postby rossint » Sun Feb 14, 2010 11:08 pm
I've had a chance to get the car nice and hot and it's surprising how well this works, I haven't done any real measurements but just using my hand the induction pipeing and under bonnet temps feel noticably cooler.
Users browsing this forum: No registered users and 230 guests
