Harness Installation - Eye Bolt Question
two40
Postby two40 » Wed Feb 10, 2010 4:44 pm
I need to secure a harness and I've got all the eye bolts in place except the sub belt ones. Just wondering if the backing plate needs to be welded underneath the car or whether you just drill the hole and bolt it, securing it with the spring washer (bendy washer) supplied?
cheers
George
WTB
- Early NA Radio
- Crash pad for '89 NA
headlightsgoup.com
Postby bruce » Wed Feb 10, 2010 5:03 pm
First thing to note; harnesses are not street legal unless engineered.
Secondly; you need to think about angles of the harness in case of crash. Thus you need to consider where the eye bolts will go.
Thirdly; your backing plates need to be of a heavy enough gauge and shape of steel.
two40
Postby two40 » Wed Feb 10, 2010 5:23 pm
Thanks mate. Now as for the actual question I asked, does the plate need to be welded?
George
WTB
- Early NA Radio
headlightsgoup.com
Postby bruce » Wed Feb 10, 2010 5:47 pm
No it doesn't. But I can't see exactly what you're doing, so be it on your own head.
two40
Postby two40 » Wed Feb 10, 2010 6:03 pm
Cheers Bruce. I know all about the angle and width. The plate came with the harness and looks well suited. It's not for street use anyway.
Thanks again.
George
WTB
- Early NA Radio
headlightsgoup.com
tbro
Postby tbro » Wed Feb 10, 2010 6:45 pm
George,
Have a looksee in the CAMS online manual. It explains all and no it does not have to be welded.
Terry
greenMachine
Postby greenMachine » Wed Feb 10, 2010 8:53 pm
Yes and no.
No, it doesn't HAVE to be welded.
Yes, welding (or other fixing) makes it a lot easier to remove and replace the bolts ...
:mrgreen:
NMX516
Postby NMX516 » Wed Feb 10, 2010 9:22 pm
Mine is riveted on, and engineer approved i.e I have a QLD Transport mod plate for it.
wun911
Postby wun911 » Wed Feb 10, 2010 10:53 pm
http://www.schrothracing.com/main/Media
there is an interesting pdf on the dos and donts of installing a harness, it explains the angles needed for the 5th point.
every ounce counts
two40
Postby two40 » Thu Feb 11, 2010 8:37 pm
One more question. Apart from some silicone to seal the drilled hole, should I look at some anti-rust paint or something of that nature?
George
WTB
- Early NA Radio
headlightsgoup.com
Benny
Postby Benny » Fri Feb 12, 2010 5:02 pm
two40 wrote:One more question. Apart from some silicone to seal the drilled hole, should I look at some anti-rust paint or something of that nature?
It wouldn't hurt to rustproof the holes.
In 10 years tme, when you may really need that harness to work, you'll be happy that it won't pull through the rust!
