Hey all,
Well Scooter is now sitting in the shed waiting for the 13th/14 Feb to go play.Looking BORED!!!!
So how does he go, Very nicly thank you!!!
Did the head work make any difference? Well, when you misses tells you that she can hear you from 3 blocks away and your not up it then I'd say that it's breathing very well!!! Had to take it down and have a resonator fitted to bring it back to what it was, sh8t it was noisy!!!!
its looks so stock
New Toyo 888's tyres to pick up during the week for Sunday and I'll run the old Dunlops for practice and Sprints on Saturday!!
I picked up the cams from Tighe Cams on Friday and was told some VERY interesting info about them.
According to Dean Tighe these cams are a custom set made for Murray Coote's Familiar and are the only set ever made
.Dean explained all about the cams and what grid they are, 725C which are the same grind used on DJR's Cosworths, mega torque and big HP gains, so the question remains ,Where did Steve get these cams from????. I'll probably try these out after the Top Gear event.
I need to replace one coil pack as the 1/4 pack is behaving badly, every so often it drops a cylinder, runs like sh*t then after cooling down all is good.
I also checked the QFM brake pads during the week ready to fit new ones for Sat, but the old ones after 8 or so track jaunts and a bit of testing and some running around have worn down exactly .1 mm F & R. At this rate the new one will be sitting on the shelf for a bloody long time.
So no more to add will let you know how Scooter and I go!!!
Terry
