Alternative firewall inlet based cold air intake
davo5
Postby davo5 » Sun Jan 17, 2010 10:53 pm
Thought i would share, I have abit of a fetish for tinkering with things but trying to keep it all as OEM looking as possible.
The airbox is out of a Mondeo, its roughly 20% bigger in volume and filter area than the MX5 one, took a while searching the wreckers to find something with the inlet / outlet in roughly the right places.
Plan is to fab an adapter bracket for the AFM using a square block of aluminum (which could then easily be substituted for a different one to support a larger AFM, or none at all) , the inlet is going to be a little tricky because its a diagonal oval shape.
Small wires make big fuses.
Fatty
Postby Fatty » Sun Jan 17, 2010 11:00 pm
nice idea. i like the oem look to. it'll be interesting to see your progress on this, good luck and keep the pics coming
Postby Jeo » Sun Jan 17, 2010 11:33 pm
Looks cool so far. Keep us posted mate.
sweep77
Postby sweep77 » Mon Jan 18, 2010 3:36 pm
how is this going to be better than standard? its still going to be drawing hot air from the engine bay. Or are you still drilling a hole in the firewall?
Postby Jeo » Mon Jan 18, 2010 5:45 pm
I would imagine so Sweep
Postby hks_kansei » Tue Jan 19, 2010 1:24 pm
Mondeo airboxes have a snorkel out one side to draw air from behind the passenger side guard, I presume that Dave's plan is to turn the airbox (as in the pic) and use the snorkel inlet to draw air from a firewall hole.
