MX5 Rover V8
olboy
Vehicle: NA6 - Turbo
MX5 Rover V8
Postby olboy » Wed Jan 13, 2010 6:07 pm
Anyone ever seen one
I recon it would be a good conversion, small alloy.
But I'm new to mx5s so it may have been done and I missed it.
Any comments?
olboy
Fatty
MX5 Rover V8
Postby Fatty » Wed Jan 13, 2010 6:15 pm
yeah i remember seeing something about this being done in the UK. can't remember where i saw it tho.
Steampunk
MX5 Rover V8
Postby Steampunk » Wed Jan 13, 2010 7:50 pm
16bit
Vehicle: NB8A - Supercharged
MX5 Rover V8
Postby 16bit » Thu Jan 14, 2010 12:04 pm
very pointless - only do it for noise. you want 3.5l do a nissan v6 conversion. should be able to get 400hp with not too much trouble. not to mention it will be more reliable and fuel efficient.
olboy
MX5 Rover V8
Postby olboy » Thu Jan 14, 2010 12:16 pm
is that the VG30 arn't they cast iron and double overhead cam, too heavy too wide too expensive?
I just thought the rover might be cheep exersize
MX5 Rover V8
Postby 93_Clubman » Thu Jan 14, 2010 12:41 pm
olboy wrote:is that the VG30 arn't they cast iron and double overhead cam, too heavy too wide too expensive?
you must have seen that recent episode of top gear which featured the 3.5 V8!
it's probably a cheap engine to source, but the total conversion exercise into an mx5 won't be cheap.
MX5 Rover V8
Postby bruce » Thu Jan 14, 2010 12:57 pm
Do a search on 'v8' on the forum and you will see the discussions. No engine conversion is cheap, nor easy in a 5 (even converting a 1.6 to a 1.8!).
Rover v8 is an old motor. Legally you will need the newer version as the motor cannot be older than the car. Leads us to Lexus v8...
olboy
MX5 Rover V8
Postby olboy » Thu Jan 14, 2010 4:37 pm
yeh i sorta thought that if an LS motor fits then a 3.5 rover would fall in but it seems that the rover motor is about the same size anyway.
16bit
MX5 Rover V8
Postby 16bit » Thu Jan 14, 2010 5:56 pm
not the vg 30. its the vq35hr which is all alloy. here are all the vq engines.
http://en.wikipedia.org/wiki/Nissan_VQ_engine#VQ35HR
Craig
MX5 Rover V8
Postby Craig » Thu Jan 14, 2010 5:59 pm
Just bolt in an SE Turbo engine from a 2004/5 model and make your life an easy one.
