Engine torque damper or aftermarket engine mounts?
Postby NitroDann » Fri Jan 01, 2010 7:18 pm
As the title says, should i make up a torque damper or go with new engine mounts, and where could i get stiffer engine mounts?
Dann.
Postby NitroDann » Fri Jan 01, 2010 7:20 pm
Also, has anybody made a rear undercarriage brace that used a tie rod so that you can put some tension on it like a strut tower brace?
rascal
Postby rascal » Fri Jan 01, 2010 7:47 pm
I think the consensus was that the engine dampers weren't really worth the effort..
I got stiffer engine mounts for my NB online from Derrick at Corksport in the US. US$69 pr.
Cheaper than sourcing locally, even with postage costs...
Postby NitroDann » Sat Jan 02, 2010 6:16 pm
Great, I have an NA6, please direct me to where i can get solid mounts, or i may just make a rubber mounted solid torque mount or 2 like my rally car has.
EDIT: So no idea on the adjustable rear arm brace?
Russellb
RIP Nov 2014
Postby Russellb » Sat Jan 02, 2010 7:58 pm
I use the cheapest Engine damper I can find from Ebay on the race car
The amount of dampening they do is AMAZING . after 10 laps of wakefield the unit is VERY hot to touch
and there are no side effects like Soild mounts . I highly recomend them for motorsport.
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Postby NitroDann » Sat Jan 02, 2010 11:37 pm
Great. Is it the one off ebay from usa. Because the ones I've seen don't lookcompatible with my mania style intake.
Postby NitroDann » Wed Jan 06, 2010 11:00 pm
Cheers, PM sent.
Well theres not much interest in my project by the looks of it but ill keep my adjustable bracing attempt updated.
jerrah
Re: Engine torque damper or aftermarket engine mounts?
Postby jerrah » Thu May 26, 2011 10:08 am
What did you end up doing Dann?
1991 MX5
Postby NitroDann » Thu May 26, 2011 11:02 am
I bought the engine damper I PMd about. Then broke an engine mount, made my own engine mounts that have adjustable stiffness then onsold the engine damper to chriss on here for half what i paid. Haha.
My new homemade ones are tits, I can make them eom soft, or softer, and i can make them so tight the dash wants to fall out, in about 1 minute.
rascal
Postby rascal » Thu May 26, 2011 1:04 pm
NitroDann wrote:My new homemade ones are tits, I can make them eom soft, or softer, and i can make them so tight the dash wants to fall out, in about 1 minute.
Thats impressive, got any pics??
Postby NitroDann » Thu May 26, 2011 1:39 pm
There is one in the how easy is it to do engine mounts at home thread.
Basically you cut the rubber completely from the factory sandwich plate mounts. Then you press out the studs that secure each side to the engine and subframe. Then you replace the rubber centre with whatever material you please. I used 3 layers of conveyor belt bonded together. Drill a hole through the rubber so that you can push a long bolt all the way through the mount, where the studs came out. Tack weld the head of the bolt so that it holds the mount to the engine plate(the other part of the mount) and so that it doesnt spin when you tighten it down. Then install it. its adjustable because when you tighten it it compresses the conveyor belt. Use locktite to secure the nut. And just tighten or loosen the nut a turn or 2 to adjust it. The nut it accessable without even jacking the car up.
Ill post detail pics if anyone wants to see how to do it. I did this when my mounts broke, it costs me about 8 dollars.
red devil
Postby red devil » Tue May 31, 2011 9:29 pm
Mate i would be keen to see your enginemounts if you dont mind posting some pics
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
Tedsmx5
Vehicle: NA8 - Supercharged
Postby Tedsmx5 » Tue May 31, 2011 9:45 pm
NitroDann wrote:Great, I have an NA6, please direct me to where i can get solid mounts, or i may just make a rubber mounted solid torque mount or 2 like my rally car has.
Not cheap, but I bet you could fabricate them yourself :mrgreen:
http://www.good-win-racing.com/Mazda-Performance-Part/61-0846.html
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
plohl
Postby plohl » Wed Jun 01, 2011 12:30 pm
Would there be much of an issue with clearence using rodend's for the chassis brace? I suppose it depends on where you where thinking of bracing it.
plohl
Postby NitroDann » Wed Jun 01, 2011 12:50 pm
The easiest way is to buy tie rods from a high tensile bolt place, you can get them in reverse threads and you just use a threaded rod in between.
In regards to my adjustable mounts,
Ill take a standard one and do a write up showing how its done.
