Newbie Question
Newbie Question
Hi guys. This is a bit of a stupid question but are the hard tops that people purchase for the NA model mx-5s, are these designed to be taken on and off easily so that the car can be dríven without a top or were they designed to turn the soft top roadster that the mx-5 is into a coupe?
- philz
- Wheel guru
Newbie Question
It's so you can take it easily off and on, on for the colder months, off in summer
- GS
Newbie Question
Yup, Philz is right. Removing the hardtop is a quick process. Flip open 2 clips above the windscreen, 2 clips behind the doors, move the hardtop forward a few cm's to move it off the 'frankenstein' bolts that are located on the boot, and lift it off. With 2 people its a 1 minute job. Its even possible to do it solo (just be really careful not to drop the thing and chip your paintwork )
1989 NA6
Newbie Question
the process might be reasonably quick but if you like top down motoring you have to make the call before leaving home. You also need somewhere to store it. I reckon the retractable hard top on late models is popular because of its convenience.
Newbie Question
GS wrote:Yup, Philz is right. Removing the hardtop is a quick process. Flip open 2 clips above the windscreen, 2 clips behind the doors, move the hardtop forward (slide the top rearward) a few cm's to move it off the 'frankenstein' bolts that are located on the boot, and lift it off. With 2 people its a 1 minute job. Its even possible to do it solo (just be really careful not to drop the thing and chip your paintwork )
As a BB the solo removal process is actually starting to "test" (:frown: ) my physical prowess, but I occassionally manage it OK.
Make something idiot-proof, and somebody will make a better idiot.
2007 Limited Edition (back in the saddle again)
- 7Hazi
Newbie Question
I haven't found my hardtop hard to take off the car... I haven't taken the hardtop off since I bought it
Users browsing this forum: No registered users and 238 guests
