Eyeball vent droop is there a cure??
Caffeine
Postby Caffeine » Sat Dec 19, 2009 8:05 pm
Millroy wrote:consider selling the remainder in small ready to use strips?? make a 'fortune' on this forum :-))
Haha good idea :)
mazdatenfive
Postby mazdatenfive » Sat Dec 19, 2009 9:15 pm
Just wondering if anyone knows an easy way to separate the eyeballs parts to make it easy to replace the sponge material.
Caffeine
Postby Caffeine » Sun Dec 20, 2009 9:10 am
mazdatenfive wrote:Just wondering if anyone knows an easy way to separate the eyeballs parts to make it easy to replace the sponge material.
I had a good try at doing just that, gave up when it was clear I was going to break them before I got them apart.
Ended up using a citrus based label remover spray, letting it soak for a few minutes, pulling the old foam out with tweezers, and then washing the vents in dishwashing liquid.
KAM
Postby KAM » Mon Dec 21, 2009 10:49 am
The eyeballs can be taken apart without damaging them.
Its a fair time since I repaired mine but the front ring is clipped onto the base, use a small screw driver to lever the front off then the eyeball falls out. The old felt can be removed and replaced and then clip the front back on 8)
Silver 2001 NB8B
Caffeine
Postby Caffeine » Mon Dec 21, 2009 11:21 am
KAM wrote:The eyeballs can be taken apart without damaging them.
I tried a variety of small screwdriver, and each was more damaging to the clips than the last!
Users browsing this forum: No registered users and 250 guests
