Timing check question
Russellb
RIP Nov 2014
Postby Russellb » Sat Dec 19, 2009 11:01 am
Adam_NAclubman wrote:Turbo & Autronic... I need 10 degrees
Did the tuner you use change the idle setings i left in the computer?
If not then set timing at 0 at 900 rpm 5 at 1000rpm
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Adam_NAclubman
Postby Adam_NAclubman » Sat Dec 19, 2009 9:33 pm
I think he said the timing was pretty much perfect and he just added some fuel above 4000 on boost
Russell, what should I be setting the base timing to? The Sheet with the ecu said to set it to 10. I'm not touching anything in the ecu
Russellb
RIP Nov 2014
Postby Russellb » Sun Dec 20, 2009 9:42 am
Adam_NAclubman wrote:I think he said the timing was pretty much perfect and he just added some fuel above 4000 on boost
That sheet i send with the ECU was for seting the base timing with the STD ECU
With the Autronic you will need to set it a 700rpm = 20 deg adv
800rpm = 3 deg adv
900rpm = 0 adv
1000rpm = 5 adv
ther is no timing lock fuction to the SMC
My ClubmanRebuild
Adam_NAclubman
Postby Adam_NAclubman » Sun Dec 20, 2009 10:34 am
Ok, so I need to set it so that the notch is on the correct mark, depending on exactly what rpm its idling at?
The sheet said to set it to 10 degrees on the standard ecu before fitting the Autronic, so I assume it was tuned with it still at 10 degrees, that shouldn't have changed should it?
Or are the settings you are talking about changed within the Autronic software?
Russellb
RIP Nov 2014
Postby Russellb » Mon Dec 21, 2009 6:56 am
Yep with the autronic has a differant idle timing to the stock ecu
the reason is to help with stable idle
My ClubmanRebuild
cshaks
Postby cshaks » Mon Jan 11, 2010 10:55 am
Guran wrote:
Matty wrote:one mark (notch?) should be at 10, the other should be at TDC (0)
Glad to hear I wasn't giving bum advice! :D
BTW, the stock timing is 10 degrees. If you want a bit more top end, 14 degrees will keep you happy. Or 18 degrees will provide more mid range torque but might require 98 RON.
When setting the timing you should also set the idle speed to 850rpm using a multimeter to measure the idle. The dash tacho isn't sufficiently precise.
There is a very useful guide ( with pictures ) to changing the timing on an MX5 here
I've just bumped mine down from 18 deg to 14 deg. (Mines an NA8)
I found that on very hot Melbourne days (38+ degrees) I was starting to get some pinging, even whilst running 98 RON fuel. (which I use exclusively)
I've also found that I think I like the feeling of the engine better at 14 now, its shifted the torque band slightly higher???
Chris
SOLD: '95 NA8 White with custom tan leather. BD bar, King Springs, 15" NB alloys.
Now driving a Mazda6 luxury sports.
