bump stops???
broady
bump stops???
Postby broady » Sat Nov 28, 2009 2:41 am
what's the cost of such top mounts and what difference does it make?
人馬一体 NA8
6/5/2010
Juffa
bump stops???
Postby Juffa » Sun Nov 29, 2009 1:42 pm
broady wrote:what's the cost of such top mounts and what difference does it make?
USD$263 + shipping
Read the following link
http://www.flyinmiata.com/index.php?dep ... %20%2010MM
buz 138
bump stops???
Postby buz 138 » Mon Dec 07, 2009 5:59 pm
i bought a set of BC coilovers yesterday.
should be here in the next couple of days :D
from what i have read in a post in another thread the rear ones still dont have much travel? i'll see if a can adapt the fly'n miata top hats onto the coilovers possibly?
i doubt it would work/be safe without a reducing type bush.. because of the smaller spring diameter??
buz 138
bump stops???
Postby buz 138 » Thu Dec 17, 2009 8:06 pm
ok so finally got the coilovers yesterday.
good looking piece of gear.
what i have noticed though is the bump stops they come with...
what is your view on me putting the fly'n miata bump stops in place of the BC ones as they seem as hard as the standard ones??..
..or could this compromise the operation of the BC's in some way??
cheers
kris
Juffa
bump stops???
Postby Juffa » Thu Dec 17, 2009 9:54 pm
buz 138 wrote:ok so finally got the coilovers yesterday.
cheers
kris
I would assume that the supplied bumpstops are matched to the coilovers. Unless one of the other BC owners objects I would stay with them. You can always swap them over to experiment down the line.
J
buz 138
bump stops???
Postby buz 138 » Sat Dec 19, 2009 12:08 am
yeah i spose i can pull them out again if i really want to ( im getting pretty good at it now :D )
so i just finished putting them in...have only dríven it with the rears in and it felt heaps better!!
i have left the height and spring rate as they were out of the box atm but put the damp to 15 clicks (half way) all round.
i'll let you know how it all goes.
also got it back from a tune at AVO today...whent in with 70rwkw on about 5psi...came out with 128rwkw on 15psi (made 120 on 12psi) heaps better car than a week ago!!
