NA6 stopped dead. Electrical issues.
- StanTheMan
- Fuzzlet
StanTheMan wrote:when it comes to a bug hunt in the electrical system is when I panic.
In the 12 months of owning my MX ive had to chase more gremlins than I can remember......arm yourself with a wiring diagram and its not too hard
- Boags
- StanTheMan
Well Boagsy. Its been running fine for the last 4mths. I did get a new pump, but haven't had the chance to install it. Just dreading to have to take out the roll bar really. But once you're at it , It would probably only take 20min. So you could call me somewhat lazy. If my Pump goes......I hope its near home.
- StanTheMan
Patchy's stopped dead.
Right so I never replced that fuel pump. I still have it under the house.....somewhere.
so I had a problem with the windscreen wiper motor. It stopped working.
so I was under the dash changing fuses & replaced the offending one. I have no idea wht fuse goes where but there is heaps of empty spots. but the wiper motor started working again.
But the car will not start now.
scenrio 1 is that the fuel pump has given up the ghost.
scenario 2 is that possebly another fuse has blown which drives the fuel pump?
there is 1 fuse under the dasg which is a bit more solid heavy duty type I've pulled it out & put it back. what does it drive?
however
I tried ampz tick with the F/P & GRD....ignition on.....no hissing
checked the spark plugs. Dry.
however
- bigdog
- King of the kennel
http://mx5cartalk.com/forum/viewtopic.php?f=55&t=37499&p=487016&hilit=fuse#p487016
Engine fuse? Replace all of them one by one till it starts. 99% odds it is a fuse.
~edit:STM~
fuse box under dash NA6
That image supplied by Juffa is pretty useful. It helped me out massively. thanks for the link
~edit:STM~
We had a club member have their fuel relay die on Sunday, you might have the same problem. I'm pretty sure that big black relay top right is the relay for the fuel pump, you need to jump the power diagonally across 2 of the 4 points (sorry cant remember which pair it is).
Since you've already tried to trigger it from the diagnosis port without luck then if the fuel pump comes on then it'll be a dead relay.
- StanTheMan
bigdog wrote:http://mx5cartalk.com/forum/viewtopic.php?f=55&t=37499&p=487016&hilit=fuse#p487016
That's tops.
But unfortunately.....not the fuse.
I'll try Okibi's trick tonight.
- ampz
- Vehicle: NA6 - Turbo
My money is on a fuse feeding the adaptronic.
Are you able to talk to it via the laptop?
If so, see if cranking the engine gives you an rpm reading on the adaptronic live guages.
Give us a call I have some time tonight.
Huh?
- StanTheMan
havent tried that.
I'll check with the missus for tonight. & make sure we have some food in the house.
- ampz
StanTheMan wrote:we have some food in the house.
Are you trying to fatten me up?
Huh?
- StanTheMan
right Patchy is back in action.
A huge thank you to ampz......who is just a wizzard.
Long story cut short.
it wasn't the fuel pump. It wasn't any relay, it wasn't the alarm fuel cut out, it wasn't a fuse & it wasn't the adaptronic.
It was a dodgy loom which plugs into the fuel pump.
It now has a temporary fix. It will have to be replaced but basically the 12 volt wire had to be pushed back in.
- StanTheMan
Also moving this thread into electronics and changed heading to something more apropriate.
- StanTheMan
StanTheMan wrote:right Patchy is back in action.
it wasn't the fuel pump. It wasn't any relay, it wasn't the alarm fuel cut out, it wasn't a fuse it wasn't the adaptronic.
I'm also assuming this was the same problem almost 3 years ago.
I never did attempt to change that fuel pump. The original pump is still working fine. I'm just grateful the plug stopped working when Patchy was parked in my front yard.
Talk about a thread being relevant for 3 years....or taking that long to fix a problem
That's got to be a record.
