How long do shocks take to wear in?
Nark
Postby Nark » Fri Nov 20, 2009 11:06 pm
Hi all,
I got Tein SSs installed 2 weeks ago. The springs are pretty much bedded in but I can still feel the shocks losing that hard edge more and more as I drive.
I'm just wondering when I can expect them to be settled. I've done roughly 600km.
bin
Postby bin » Sat Nov 21, 2009 12:28 am
I'd say they would have settled the first 30mins of driving after you installed them.
I'm guessing the reason why you say they're still "losing that hard edge" is because you're getting more and more used to the stiffness of the shock.
Someone please correct me if I'm wrong.
philz
Wheel guru
Postby philz » Sat Nov 21, 2009 12:38 am
Say you were lifting your wheel up from the ground to do some servicing etc, then it would take overnight for the springs to settle in, which is what the OP has mentioned.
Shocks take a while... probably 5000km? it will also go lower.
Nark
Postby Nark » Sat Dec 19, 2009 10:59 pm
FWIW, it took about 1,000km for the shocks to fully soften up, then another 500km to really truly settle.
Users browsing this forum: No registered users and 106 guests
