A/C Install
A/C Install
I can't see why not... you could go to the parts desk at your local mazda dealer and check the part numbers between the different models.
- Boyracer
- MX-5 Encyclopedia
A/C Install
Will bolt straight in as long as it is the same type of system...there are 2...one is the Aussie version which was fitted by dealers and the other is the Jap. version...there are quite a few differences...main one is the Jap version has and oval shaped fitting that goes throught the firewall...the aussie version has two separate holes going through the firewall.
