Fuel Consumption
7Hazi
Fuel Consumption
Postby 7Hazi » Mon Nov 09, 2009 2:50 pm
Hey everyone,
Is it normal to only be getting 235 km (around that) per full tank on a '94 NA8 (Eunos) with about 76000 km? I have a feeling something is wrong as there was a time I was able to get close to 300km per tank, then it went down to around 260 km, and then when I filled it up this afternoon I was only on 235km (and the tank was pretty much empty as i was able to put 39 litres in).
With regards to engine mods, it is pretty much stock (as far as I am aware) other than a pod filter. Also, I don't drive around launching it everywhere so I don't think the driving is what is using the excessive amounts of fuel.
Any help would be greatly appreciated.
Thanks
broady
Fuel Consumption
Postby broady » Mon Nov 09, 2009 3:09 pm
Definitely not normal. I drive spiritedly ... everywhere, short trips etc and still manage 350 km+ to a tank (usually around 11L/100km)
人馬一体 NA8
6/5/2010
Szemen
Fuel Consumption
Postby Szemen » Mon Nov 09, 2009 3:21 pm
'95 NA8. Intake mods and cat back exhaust. Hasn't made a difference in Fuel consumption. I'm still getting about 8.2-8.5L/100km consistently. That's with giving it a good hammering through the gears when I go onto the M5 =D About twice a week, otherwise its normal driving. Spirited drives doesn't change it that much, not going through the national park anyway.
StanTheMan
Fuel Consumption
Postby StanTheMan » Mon Nov 09, 2009 4:03 pm
standardish NA8 you should be getting around 400-450 km per tank.
400ish if you do lots of short trips with launching everywhere.
Szemen
Fuel Consumption
Postby Szemen » Mon Nov 09, 2009 4:07 pm
StanTheMan wrote:400ish if you do lots of short trips with launching everywhere.
Or traffic jams T_T
Fuel Consumption
Postby Jeo » Mon Nov 09, 2009 4:08 pm
Something isn't right there. Fuely smell coming from the exhaust?
Fuel Consumption
Postby bruce » Mon Nov 09, 2009 4:17 pm
Blocked or dirty air filter? Is there a duck stuck in the intake pipe?
7Hazi
Fuel Consumption
Postby 7Hazi » Mon Nov 09, 2009 5:45 pm
Thanks for the responses everyone. :lol: I don't think there is a duck in the intake pipe, but I'll have a look at the air filter, probably is dirty from those previous dust storms (fuel consumption was still crap before the storms though). I have noticed that after I go for a drive and park the car in the garage you can definitely smell fuel so if that helps... Anyone have any other ideas as to what could be wrong and if so how to fix it? It would be awesome to get over 400km per tank :P
Dweezle
Fuel Consumption
Postby Dweezle » Mon Nov 09, 2009 9:21 pm
7Hazi - i am having exactly the same issue in my NA6... hope you find a answer and let us all know :wink:
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Old Dude
Fuel Consumption
Postby Old Dude » Tue Nov 10, 2009 3:10 pm
If you go for a drive and you smell fuel, you may have a fuel leak :shock: maybe in the tubing or around the engine :? I go for a good run in mine and all I smell is hot engine smell, never fuel.
Dale 8)
MX 5 2001 Grace Green
NB8B
Old Dude
Fuel Consumption
Postby Old Dude » Tue Nov 10, 2009 3:12 pm
Just had another thought check your hose clamps to the tank, I had this problem with my boat and the fuel was evaporating, tightened them up and no more problem.
Old Dude 8)
NB8B
Adam_NAclubman
Fuel Consumption
Postby Adam_NAclubman » Tue Nov 10, 2009 7:52 pm
How do you have a NA8 Eunos in Brisbane?
7Hazi
Fuel Consumption
Postby 7Hazi » Tue Nov 10, 2009 8:57 pm
I am going to fit the stock airbox on the weekend to see if that makes any difference. Old Dude - I don't smell petrol when I'm driving around, only if the car has been sitting in the garage for a while after a drive. If changing the air filter doesn't really do anything then you might be right in thinking there might be a leak or something, in which case I'll look into it. Thanks for the suggestions :D
Adam_NAclubman - What do you mean how do I have an NA8 Eunos in Brisbane? :? . I bought it and it was an import? :lol:
Old Dude
Fuel Consumption
Postby Old Dude » Tue Nov 10, 2009 9:01 pm
Sorry 7Hazi thats what I meant, you shouldn't be smelling petrol when the car is just sitting there unless it is escaping from some where.
Dale 8)
NB8B
Benny
Fuel Consumption
Postby Benny » Wed Nov 11, 2009 10:44 am
Check your boot for a fuel smell.
If so, one of the small rubber hoses that lead from the filler tube may be cracked and allowing fuel to evaporate.
Users browsing this forum: No registered users and 101 guests
