A/C Install
Mazfan
A/C Install
Postby Mazfan » Tue Nov 10, 2009 6:47 pm
HI all,
Will a A/C from a 2002 model NB fit straight into my 2001 NB? Do you have to do any hot wiring?
Thanks
A/C Install
Postby Okibi » Wed Nov 18, 2009 9:54 pm
I can't see why not... you could go to the parts desk at your local mazda dealer and check the part numbers between the different models.
Boyracer
MX-5 Encyclopedia
A/C Install
Postby Boyracer » Fri Nov 20, 2009 6:57 pm
Will bolt straight in as long as it is the same type of system...there are 2...one is the Aussie version which was fitted by dealers and the other is the Jap. version...there are quite a few differences...main one is the Jap version has and oval shaped fitting that goes throught the firewall...the aussie version has two separate holes going through the firewall.
Users browsing this forum: No registered users and 273 guests
