15x7 with offset -12
Would these fit an NA...? (tires 205/50/15)
2007 Megane F1 R26. 1992 NA6. 1993 205 GTI series 3.
Not with those Tyres.
Even with stretched tyres you would have too much poke and need to be slammed for the wheels to look any good on the car.
- broady
You'd probably want flares.
人馬一体 NA8
6/5/2010
ok... the add says they fit RX2, RX3 & RX7 (thought the MX5 would be close...
- Jeo
RX2 and 3 aren't 4x100 either
- green_comet
- Car Detailing Guru
That size wheel would sit the same as 15x8 0et wheel. You can pull it off but you need to roll/pull guards, slam your car, and run a fair amount of camber. Those tyres would have to go for some 195/50's or thinner.
cosmo wrote:ok... the add says they fit RX2, RX3 & RX7 (thought the MX5 would be close...
RX2/3 PCD = 4X110
RX7 Series 1 PCD = 4x110 (possibly series 2 as well)
NA/NB MX5 PCD = 4x100
Thanks guys.....didn't want to slam car in any way, so might pass on them...
cosmo wrote:Thanks guys.....didn't want to slam car in any way, so might pass on them...
wont fit anyway, the wheel studs on the early RX series (RX2/3) are 10mm further apart than on an MX5.
Users browsing this forum: Google [Bot] and 2 guests
