just wondering if i can just rotate the left ones to run the wrong way as there is pleanty of tread on the outsides and want to use them on my first track day in december
Cheers, Craig.
CapitalF wrote:You must mean the right hand side when facing the car from the front otherwise your comments don't make sense. Then again I've had few ales!
Am I correct re direction?
And yes, the comments thus far are spot on.
And yes, R888's provide amazing grip (unless v old / hard)
Peter
Steve - Toyo Tyres wrote:In theory you may open up the tread splice-joint by running them backwards.
I have seen R888s run backwards many times without any problems.
The tread pattern only works in wet conditions.
JBT wrote:Steve - Toyo Tyres wrote:In theory you may open up the tread splice-joint by running them backwards.
Would this also apply to R1Rs to even out track wear Steve?
hks_kansei wrote:if they are camber worn cant you just swap them left to right to even it out?
ie the left side tyres become the right side ones, and vice versa.
