r888's
mxfive95
r888's
Postby mxfive95 » Fri Oct 30, 2009 11:17 pm
I have a full set of r888's that i bought second hand very cheap but it seems they must have came off two cars as all the right hand corners have worn down.
just wondering if i can just rotate the left ones to run the wrong way as there is pleanty of tread on the outsides and want to use them on my first track day in december :D
Cheers, Craig.
The bumper sticker on my porsche
"My other car is an mx5"
Steampunk
r888's
Postby Steampunk » Sat Oct 31, 2009 1:02 am
There was a guy who ran the rear set back-to-front for the entire track-day without realising it, until I pointed it out to him.
He wasn't bothered by it and left it. he's a pretty hard charger on track.
broady
r888's
Postby broady » Sat Oct 31, 2009 3:25 am
Just don't drive in the wet O_O
人馬一体 NA8
6/5/2010
PUR157
r888's
Postby PUR157 » Sat Oct 31, 2009 1:45 pm
It's been said that running reverse rotation can attribute to faster wear... anyone have any experience with this?
Oneness of Man and Machine
Alex
r888's
Postby Alex » Sat Oct 31, 2009 1:52 pm
Seems some people do it to even out wear
viewtopic.php?p=504090#p504090
NMX516
r888's
Postby NMX516 » Sat Oct 31, 2009 2:34 pm
I've run them in the opposite direction a couple of times to even out wear when I didn't have the chance to get the tyres swapped on the rims... Works fine, no ill effects, but must be done in the dry only.
d-mag
Road Track Rally
Vehicle: ND - Turbo
r888's
Postby d-mag » Sat Oct 31, 2009 9:07 pm
Hey Craig, run em' backwards mate, but as said already, only in the dry. :wink:
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
CapitalF
Vehicle: NA6 - Turbo
r888's
Postby CapitalF » Sat Oct 31, 2009 11:05 pm
You must mean the right hand side when facing the car from the front otherwise your comments don't make sense. Then again I've had few ales!
Am I correct re direction?
And yes, the comments thus far are spot on.
And yes, R888's provide amazing grip (unless v old / hard)
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Steve - Toyo Tyres
r888's
Postby Steve - Toyo Tyres » Mon Nov 02, 2009 8:31 am
In theory you may open up the tread splice-joint by running them backwards.
I have seen R888s run backwards many times without any problems.
The tread pattern only works in wet conditions.
mxfive95
r888's
Postby mxfive95 » Tue Nov 03, 2009 3:26 pm
Great thanks for everyones comments, ill be putting them on this week as i want to do a track day soon and the potenza g3's i'v got have gone hard and only good for drifting of skid pan 8)
Peter yep your'e right! i meant to say the insides of the left wheels are worn, as for age they are late 2007 with plenty at least 40% tread on the outsides and were pretty cheap :D Cheers d-mag
CapitalF wrote:You must mean the right hand side when facing the car from the front otherwise your comments don't make sense. Then again I've had few ales!
Peter
Craig
JBT
r888's
Postby JBT » Tue Nov 03, 2009 7:38 pm
Steve - Toyo Tyres wrote:In theory you may open up the tread splice-joint by running them backwards.
Would this also apply to R1Rs to even out track wear Steve?
Steve - Toyo Tyres
r888's
Postby Steve - Toyo Tyres » Wed Nov 04, 2009 10:13 am
Yes
r888's
Postby hks_kansei » Wed Nov 04, 2009 3:24 pm
if they are camber worn cant you just swap them left to right to even it out?
ie the left side tyres become the right side ones, and vice versa.
broady
r888's
Postby broady » Wed Nov 04, 2009 3:41 pm
hks_kansei wrote:if they are camber worn cant you just swap them left to right to even it out?
They're directional
edit: I guess you could take the tyres off and switch sides because AFAIK they are symmetrical
人馬一体 NA8
6/5/2010
olboy
r888's
Postby olboy » Wed Nov 04, 2009 3:45 pm
I think he means still rotates in the same direction but swaps from side to side
Users browsing this forum: Google [Bot] and 339 guests
