nb8a air con belt
16bit
Vehicle: NB8A - Supercharged
nb8a air con belt
Postby 16bit » Wed Nov 04, 2009 9:08 am
hey guys just wondering if the air con belt runs off the power steering too? My air con does not work and was wondering if I could remove the belt.
rascal
nb8a air con belt
Postby rascal » Wed Nov 04, 2009 9:16 am
Yes they do share the same belt, so unfortunately no you wont be able to remove it and still have power steering.....
16bit
nb8a air con belt
Postby 16bit » Wed Nov 04, 2009 9:53 am
i assume its a massive pain in the arse to change it over yourself too?
Patty
nb8a air con belt
Postby Patty » Wed Nov 04, 2009 12:18 pm
I think wun removed parts of his air con and also bought a belt which just drove the P/S.
EDIT: Here.
Grace Green NB8A
nb8a air con belt
Postby bruce » Wed Nov 04, 2009 12:53 pm
You just need a shorter belt. Guess it is the same belt from a model without AC but has PS. Don't know if it is an easy job swapping.
wun911
nb8a air con belt
Postby wun911 » Wed Nov 04, 2009 8:09 pm
yeah its easy need only 12 and 14 mm socket with a mini extension...
every ounce counts
