ok....some people might laugh their heads off about the topic's title.
I bought a texture black voodoo from Mania on the weekend and it felt great.
However, i noticed that the voodoo doesn't go as deep as the OEM so there's now this gap between the bottom of the knob and the top of the leather bit (is it call Benny's Boot?).
I can just pull it up every now and then and the gap will disappear but obviously that's not really a fix.
Is there something (like a ring) that i can get to hold it up at the right height so that the gap will be covered?...
Installing a voodoo knob (properly)
- Mr_Q
BadBong wrote:Is there something (like a ring) that i can get to hold it up at the right height so that the gap will be covered?...
Yes there is.
(click the pic for a bigger version)
MX5 Mania used to sell them but I can't see them on their website at the moment.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Voodoo used to make those trim rings as they called them, but don't anymore.
- AJ
buy an NC, the voodoo screws right down to the boot
XMX5 Rogues
- broady
AJ wrote:buy an NC, the voodoo screws right down to the boot![]()
Pretty extreme trim ring.
人馬一体 NA8
6/5/2010
So... any other alternatives?
- greenMachine
My Voodoo screwed all the way down - the thread is tapped virtually all the way through the knob, so the knob actually sits lower than stock. I think the top of the gearstick is only a few mms below the top of the knob.
Has Voodoo Bob changed the design, or do some models have a different design so they sit higher?
greenMachine wrote:Has Voodoo Bob changed the design, or do some models have a different design so they sit higher?
there's two versions, there's a larger one (which Mania sells) and a slightly smaller one (which I dont think is made anymore)
the larger one doesnt sit flat on the leather boot usually, and unfortunately the spacer ring doesnt fit on the larger knob, only the smaller one.
in saying that though, the trim ring isnt that complicated, it would take someone with a metal lathe only a few minutes to make.
hm... looks like some good quality black cloth tape for me for now then...
- tinsfci
- Vehicle: NA - V8
I put a short piece of 13mm poly reticulation pipe over the shaft and placed a washer on top, the boot sits on the washer just below the gear knob (I have a Skunk 2). I am a dodgy bastard!
Street='94 with FFS Coldside. Sold
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
tinsfci wrote:dodgy bastard!
Confirmed.
