Extended Wheel Studs
project.r.racing
Postby project.r.racing » Sun Nov 01, 2009 9:39 pm
Anyone had any exprience with using longer wheel studs?
I wanna run some longer wheel nuts and maybe even spacers so I need the longer studs.
Ryan
p.s. I am aware that spacers are illegal on Queensland roads.
rascal
Postby rascal » Sun Nov 01, 2009 9:46 pm
I would never use spacers that require longer wheel studs as they move the load from the hub to the studs, which aren't designed to take the load.
I have however used bolt on spacers which do retain the hub mounting with no downsides in over 6 years on a track car.
wun911
Postby wun911 » Mon Nov 02, 2009 10:48 pm
Its pretty easy to install studs but generally pplz angle grind them down to reduce rotational mass...
every ounce counts
bretauto
Vehicle: NB8A - Turbo
Postby bretauto » Tue Nov 03, 2009 8:25 am
ARP do a longer wheel stud, ( approx 20mm), my wheels are thicker where they bolt up , and I wanted more engagement in the alloy nuts. ( I know it defeats the purpose, light weight wheel nuts, then fitting heavier studs.)
CT
Postby CT » Wed Nov 04, 2009 9:22 am
We use long studs on the race cars - been using them for years. ARP do them as do a few other companies - Meridian Motorsport usually stock them too. FYI the rear hubs need to be pulled apart and the bearing replaced to change the studs. Anyone who uses an angle grinder on a wheel stud deserves to hit something - hard.
bretauto
Postby bretauto » Thu Nov 05, 2009 12:37 pm
ARP rear studs for the NB have the flat in one side (like the Mazda ones) so no need to dismantle the hub.
CT
Postby CT » Thu Nov 05, 2009 2:13 pm
bretauto wrote:ARP rear studs for the NB have the flat in one side (like the Mazda ones) so no need to dismantle the hub.
I know - mine wouldn't go in....... :evil:
bretauto
Postby bretauto » Fri Nov 06, 2009 11:29 am
I had no problems fitting mine
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Sat Nov 07, 2009 12:43 am
I had no problems fitting my Nice Products studs, a little tight past the upright but they went in.
And to Rascal who made the comment about the load on the studs, that is not an accurate statement; even in the said case the load is transfered to the hub face through friction, the studs are loaded in tension as normal.
Tim
