Hi I suggest you take the switch apart,quite easy,and clean the terminals with a fine emery paper and WD40.What you describe is a common problem.
WASP
ps Why not add your Suburb or City in profile
power windows
power windows
Also you should get inside the door and lube the sliders, rubbers and cable etc, replacing those is a PITA much easier to try and maintain them so they don't snap.
- Wuey
power windows
WD40 is only a very temporary measure. It will eventually gum up and stuff the connectivity. Electrical contact cleaner available from your local electronic store works better.
