Gday
My power windows on my 89 eunos will go down but they will only go up after i push the switch 4 million times.Its only on the drivers side window but today it took 5 pushes of the switch to get the passenger side up.It could be the switch but i tinted the windows a couple weeks back so could the water from the tints damage the
wires/cables.any thoughts?
thankyou
power windows
power windows
Hi I suggest you take the switch apart,quite easy,and clean the terminals with a fine emery paper and WD40.What you describe is a common problem.
WASP
ps Why not add your Suburb or City in profile
WASP
power windows
Also you should get inside the door and lube the sliders, rubbers and cable etc, replacing those is a PITA much easier to try and maintain them so they don't snap.
- Wuey
power windows
WD40 is only a very temporary measure. It will eventually gum up and stuff the connectivity. Electrical contact cleaner available from your local electronic store works better.
Users browsing this forum: No registered users and 48 guests
