r888's
- mxfive95
r888's
I have a full set of r888's that i bought second hand very cheap but it seems they must have came off two cars as all the right hand corners have worn down.
just wondering if i can just rotate the left ones to run the wrong way as there is pleanty of tread on the outsides and want to use them on my first track day in december
Cheers, Craig.
Cheers, Craig.
The bumper sticker on my porsche
"My other car is an mx5"
- Steampunk
r888's
There was a guy who ran the rear set back-to-front for the entire track-day without realising it, until I pointed it out to him.
He wasn't bothered by it and left it. he's a pretty hard charger on track.
- Alex
r888's
Seems some people do it to even out wear
viewtopic.php?p=504090#p504090
r888's
I've run them in the opposite direction a couple of times to even out wear when I didn't have the chance to get the tyres swapped on the rims... Works fine, no ill effects, but must be done in the dry only.
- CapitalF
- Vehicle: NA6 - Turbo
r888's
You must mean the right hand side when facing the car from the front otherwise your comments don't make sense. Then again I've had few ales!
Am I correct re direction?
And yes, the comments thus far are spot on.
And yes, R888's provide amazing grip (unless v old / hard)
Peter
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
r888's
In theory you may open up the tread splice-joint by running them backwards.
I have seen R888s run backwards many times without any problems.
The tread pattern only works in wet conditions.
- mxfive95
r888's
Great thanks for everyones comments, ill be putting them on this week as i want to do a track day soon and the potenza g3's i'v got have gone hard and only good for drifting of skid pan
Peter yep your'e right! i meant to say the insides of the left wheels are worn, as for age they are late 2007 with plenty at least 40% tread on the outsides and were pretty cheap Cheers d-mag
Craig
CapitalF wrote:You must mean the right hand side when facing the car from the front otherwise your comments don't make sense. Then again I've had few ales!
Peter
Craig
- JBT
r888's
Steve - Toyo Tyres wrote:In theory you may open up the tread splice-joint by running them backwards.
Would this also apply to R1Rs to even out track wear Steve?
r888's
JBT wrote:Steve - Toyo Tyres wrote:In theory you may open up the tread splice-joint by running them backwards.
Yes
r888's
if they are camber worn cant you just swap them left to right to even it out?
ie the left side tyres become the right side ones, and vice versa.
- broady
r888's
hks_kansei wrote:if they are camber worn cant you just swap them left to right to even it out?
They're directional
edit: I guess you could take the tyres off and switch sides because AFAIK they are symmetrical
人馬一体 NA8
6/5/2010
Users browsing this forum: No registered users and 326 guests
