Cooling Pro Radiators
Adam_NAclubman
Postby Adam_NAclubman » Wed Oct 21, 2009 8:25 pm
Locutus wrote:are you sure you've closed off the tap? you close it by seemingly unscrewing it all the way.
:shock: :shock: :shock: But it would almost be hitting the ground then!!!!!
I'll try that
Locutus
Postby Locutus » Wed Oct 21, 2009 10:25 pm
Adam_NAclubman wrote: :shock: :shock: :shock: But it would almost be hitting the ground then!!!!!
yeah i had my concerns too, but if you have a look at once it's all mounted, you'll see that it'll be fine.
PUR157
Postby PUR157 » Thu Oct 22, 2009 12:10 am
I need to pipe up here...
I've been under my car recently and the head snapped off
If your car is lowered at all one careless hump and it's a goner I'm afraid... :frown:
Not the best design by cooling pro
Need to figure out how to fix that soon
Oneness of Man and Machine
Szemen
Postby Szemen » Thu Oct 22, 2009 1:07 am
What head? The coolant hose inlet head? or the drain plug head?
timk
Postby timk » Thu Oct 22, 2009 1:00 pm
I just replaced mine with a bolt, never had an issue since.
PUR157
Postby PUR157 » Thu Oct 22, 2009 3:10 pm
Szemen wrote:What head? The coolant hose inlet head? or the drain plug head?
The drain plug head!
Saboteur, easy does it, I'll remember that :mrgreen:
hot rod
Postby hot rod » Mon Oct 26, 2009 12:25 pm
I've had mine in the car for about 5 months now.
However I found a few problems over the weekend whilst replacing a few things. It appears that my radiator is suffering from electroylsis (the iside of the radiator has turned black). I was originally going to fit an earth strap but never did as I was lazy...anyway there are a lot of theories on electrolysis.
You can see here that the AC is just touching the bottom radiator tank. The AC radiator is rubber mounted but the lines touch the body in palces obivously.
I should be able to easily move this forward to alleviate that problem. I will get a multi-meter and try and determine which system has a bad earth. In the mean time I have disconnected the battery till I determine what the problem is and how to fix it. I only drive this car maybe 1-2 days per week and it starts fine after weeks of no use.
I was wondeirng if anyone has ever used a zinc anode in their radiator? They are quite common in marine racing and similar (albiet smaller) to what is insde a domestic hot water service. This is not a total solution for this problem, I need to find the source of the wayward current but I think this is a bit of security at least.
Zinc Anode Drain Plug Replacement Kit
http://www.jegs.com/i/Flex-a-lite/400/32060/10002/-1
I have also been told by a few people that I should be using red coolant in this radiator? Am currently using Tectaloy 90 green pre-mixed coolant.
Any advice would be appreciated.
tbro
Postby tbro » Mon Oct 26, 2009 8:37 pm
Hotrod,
There's no problems with running sacrificial anodes in your radiator AFTER you correct your electrical leakage and earth your radiator.
I've spent the last 30+ years fitting and replacing these bloody things :lol: :lol: Caterpillar and Cummings engines all use them.
As for the colour of your coolant, the colour is determined by the manufacture, as long as you use a good product colour is immaterial.
BTW, if you fit an anode make sure it doesn't touch the inner core of the radiator otherwise it won't work!!!
A word for the uninitiated, always follow the coolant manufactures recommendations when mixing up your coolant, overdosing is NOT better, under dosing if anything is better.
Terry
hot rod
Postby hot rod » Tue Oct 27, 2009 11:02 am
Hi Terry,
Thanks for the advice, most appreciated.
I'll make sure the anode isn't too long as you said but I will fix the earth problem first. I don't think the problem was there before the old radiator came out so it's probably an install earthing issue.
Can you recommend who might sell these anodes?
Luke
tbro
Postby tbro » Tue Oct 27, 2009 7:37 pm
Luke,
Go to a marine dealership or similiar and ask for a pencil anode, I think the best option for fitting, if there is room, would be where the drain tap is.
Unscrew the tap and fit the anode.
Terry
tbro
Postby tbro » Tue Nov 03, 2009 8:48 pm
Hmm Cooling Pro!!!
I bought a radiator from ASI in Melborne, $265 delivered to Home 4 working days after ordering it!
Now I'm worried, everything fitted straight up, no bloody washers,the lower mount pins fit and the drain plug is protected by a shoulder,even the fans line up perfectly. It seems to be manufactured reasonably well, no awards for welding neatness but for the money it'll do.
Only think I've picked up on (and remember I think too much) is that the bottom hose kinks slightly coming up to the steel pipe. I'll modify the hose and steel hose mount as my oil catch can and sway bar mounts are in the way so it needs to be modded anyway.
Terry
Postby Okibi » Tue Nov 03, 2009 10:04 pm
Great to know!
Has anyone tried the ASI one that comes with radiator fans?
philz
Wheel guru
Postby philz » Wed Nov 04, 2009 12:44 am
Seems like the ASI radiators fit better than the cooling pro, even Wazman said that he had no problems with fitment.
And it's cheaper than Cooling pro as well!
Might have a look at them.
TieNN89
Postby TieNN89 » Tue Dec 01, 2009 1:15 am
tbro wrote:Now I'm worried, everything fitted straight up, no bloody washers,the lower mount pins fit and the drain plug is protected by a shoulder,even the fans line up perfectly. It seems to be manufactured reasonably well, no awards for welding neatness but for the money it'll do.
What do you mean by the drain plug is protected by a shoulder?
It seems the cooling pro have improved so shouldn't have any fitment issues any more
So which is better ASI or Cooling Pro?
wun911
Postby wun911 » Tue Dec 01, 2009 11:34 am
I got the PWR one for a while its cool but I dont think the stock rad cap fits the aftermarket rad...
what rad cap are people using for their PWR rad??? part number etc plz??
every ounce counts
Users browsing this forum: No registered users and 109 guests
