you may need your guards rolled sometime soon *nudge nudge*
philz wrote:I'm having problems with height difference, it's about 5-10mm higher on the passenger side...
sliq wrote:a very bold colour
Szemen wrote:philz wrote:I'm having problems with height difference, it's about 5-10mm higher on the passenger side...
WEEEE! I'm not the only one with that problem
philz wrote:Why a semi slick tyre?
1000km is quite alot, and will wear out the tyres quick smart, and the noise for daily driving will be too much.
Also 16 and 17" semi slicks are quite expensive.
But hey if you are fine with all the above, more power to you![]()
Can't really help unless you have some sort of budget, wheels +tyres.
Depends if you want genuine quality wheels, light weight, cheap made, and also depends on the looks.
davekmoore wrote:Just want them to be less vulnerable. Could that be done by choosing tyres with an edge beading? If so, which tyres?
