SE Shocks/Springs into NA6
Veloce
Postby Veloce » Fri Sep 25, 2009 8:15 pm
Have been searching for a while but haven't had any success finding info on this.
What modifications/parts do I need to do this? Any help appreciated. :?
Thanks in anticipation. :)
Make something idiot-proof, and somebody will make a better idiot.
2007 Limited Edition (back in the saddle again)
philz
Wheel guru
Postby philz » Fri Sep 25, 2009 8:19 pm
take out old, put in new.
SPy vs. SPy
Postby SPy vs. SPy » Fri Sep 25, 2009 8:21 pm
A set of NB Konis & Eibachs I sold went straight into an NA, so I can't foresee any dramas.
May sit a touch higher, I mean like 2mm higher than they would on an NB, but they will lower the car from stock.
A good cost effective solution and re-buildable too.
Postby Okibi » Fri Sep 25, 2009 8:33 pm
Use the NB top hats, but it will sit higher than the same springs in an NB as spy said. I think it's more like 1cm but my NA never had stock springs so hard to tell for sure. I could measure?
Veloce
Postby Veloce » Fri Sep 25, 2009 9:38 pm
Thanks all for the rapid reply. If there are no Top Hats then I should buy new ones for an NB then! I'm guessing dimensionally they are different. Does it drop the car much? As I'm a more senior driver I don't want it too low! Already scrapes the exhaust on some of those nasty metal humps at the Chermside car park. :evil:
philz
Wheel guru
Postby philz » Fri Sep 25, 2009 9:51 pm
Shouldn't be too low, might be the same height or higher than sagged old na6 shocks/springs.
Steampunk
Postby Steampunk » Sat Sep 26, 2009 12:05 am
SPy vs. SPy wrote:A set of NB Konis & Eibachs I sold went straight into an NA, so I can't foresee any dramas.
Give us a yell if you need a hand installing.
Garry
Postby Garry » Sat Sep 26, 2009 11:08 pm
I've been told that putting the se suspension in an na will raise it up a fair bit.
I would have thought the same thing. Isn't the SE a couple of hundred kg heavier than an NA6? It would come with stiffer springs to compensate for the extra weight wouldn't it?
vespa
Postby vespa » Wed Oct 21, 2009 11:30 pm
have done it and yes makes the care V high..... not the 1cm as suggested buy others. I had the MSM springs re-set by allsprings to 5cm lower in the rear and 4cm in the front. You could probably go 3.5rear and 3 in the front if you wanted to keep it a little higher but its up to you. Im currently in the process of selecting a firmer spring to change to as the MSM ones on a drop that big are a little soft.
If your in syd and would like to come see your more then welocme.
Postby Okibi » Wed Oct 21, 2009 11:59 pm
I'd be keen know which lower springs you select and your opinion of them. I'm considering getting some for my NA6 (with NB springs/shocks).
Veloce
Postby Veloce » Fri Oct 23, 2009 8:23 pm
vespa wrote:have done it and yes makes the care V high..... not the 1cm as suggested buy others. I had the MSM springs re-set by allsprings to 5cm lower in the rear and 4cm in the front. You could probably go 3.5rear and 3 in the front if you wanted to keep it a little higher but its up to you. Im currently in the process of selecting a firmer spring to change to as the MSM ones on a drop that big are a little soft.
Forgive my ignorance ...... MSM .... stands for?
I'm going to be contacting FCM in the states and see what they suggest, not intending to go as far as perches as I'm not a 'racer' or interested in tracking.
Any way ..... will let you know the outcome.
PUR157
Postby PUR157 » Sat Oct 24, 2009 12:41 am
typically MazdaSpeed Miata, but in this context I'm not too sure, as it's a very septic term...
Oneness of Man and Machine
ampz
Vehicle: NA6 - Turbo
Postby ampz » Tue Oct 27, 2009 1:05 pm
Garry wrote:I would have thought the same thing.
The other NA6 (the white one) on the Alpine run had SE shocks and springs...
I'm unsure if the springs have been reset, but Boyracer would be able to confirm.
Mine is just a mixture of too many things to be a mainstream combo :oops:
Huh?
Veloce
Postby Veloce » Wed Oct 28, 2009 3:25 pm
Thanks for that. Is that photo out the back of Hume Weir?
Postby bruce » Wed Oct 28, 2009 4:49 pm
Low Clearance of 4.2 metres! Do elephants piggybacking giraffes use that bridge?
Users browsing this forum: No registered users and 122 guests
