Ok, those problems are now solved. Photos in my garage thread if you're interested.
New problem
Did the vac lines today then tried to start the engine, with the stock ecu. It should be able to idle on that even with the kit installed.
Unfortunately, it won't start. It cranks over nicely on the starter motor, no bearing knocking or anything, you can hear the air coming out the dump pipe going foomp foomp foomp foomp foomp (but quickly). It has spark and I could smell petrol when I pulled the plug out.
Could the timing be way off? We put a new timing belt in and it went on in the same position as the old one.
I also want to try changing the cam angle sensor for the one from my old engine but I don't know how to remove it.
Are the fuel lines connected to the right end of the fuel rail? This seemed the most logical way to do it to me
