Locutus wrote:are you sure you've closed off the tap? you close it by seemingly unscrewing it all the way.
But it would almost be hitting the ground then!!!!!
I'll try that
Adam_NAclubman wrote: But it would almost be hitting the ground then!!!!!
Szemen wrote:What head? The coolant hose inlet head? or the drain plug head?
tbro wrote:Now I'm worried, everything fitted straight up, no bloody washers,the lower mount pins fit and the drain plug is protected by a shoulder,even the fans line up perfectly. It seems to be manufactured reasonably well, no awards for welding neatness but for the money it'll do.
Users browsing this forum: No registered users and 49 guests
