wazman wrote:
Hey Wazman, what did you do with the" ventilation hose" on the exhaust side of the rocker cover (under the oil cap)? Actually, what does it do?
wazman wrote:
MXHEVN wrote:do not use tie rod spacers, if you collect something mid drift, the whole assembly will fall apart. (out comes the tie rod)
Get some secret element tie rod ends/or modify your knucles.
dorifta wrote:MXHEVN wrote:do not use tie rod spacers, if you collect something mid drift, the whole assembly will fall apart. (out comes the tie rod)
We talking mx5s only or in general?
i been using spacers for over 2 years now... not a single problem... all of the boys had no issues either.
