Does anyone know of a muffler to suit NA8, which will sound sporty, but not have any drone or excessive noise?
I just had a long trip up into the hills of Perth, and the drone and sheer volume of noise almost drove me mad, with the roof up even....
Matty wrote:depends on a lot of factors.
Do you have a resonator in the midpipe?
What sort/size tip do you have? A good trick is to make your tip slightly smaller than the rest of the piping, this will cut noise without significantly restricting the system.
2.5" is probably a bit big for an otherwise standard NA8, but should be OK with a good muffler. used OEM mufflers are generally good quality and cheap.
read a few articles on Autospeed.
sliq wrote:long trips on the highway and aftermarket mufflers don't really go well together.
what is your budget?
there are stacks of brands out there.. i would tend to go with RS R, or remus, SMB.. i.e. the quality brands..
there is also a brief exhaust database in the forum.. sift around for it, there should be a few examples you can listen to
Mr Morlock wrote:why not go with the resonator option- as the exhaust guy suggested- it will tone it down for sure and save you money.
