Straight through exaust
- Vehicle: NA6 - Turbo
Anybody ever tried doing away with the cat and muffler and running a straight through system on an na6. good idea or not, its on a race only car.
olboy
olboy
don't beat around the bush give it to me straight
- StanTheMan
No back pressure. Not sure if that's real good. Yes it will probably give you a slightly better Dyno reading But I feel Patchy likes a little back pressure. Mine was almost like what you describe. It idles better with some extra back pressure. As well my transient throttle seems to be less obvious with a little extra backpressure
- Boags
olboy wrote:Anybody ever tried doing away with the cat and muffler and running a straight through system on an na6. good idea or not, its on a race only car.
olboy
I have no cat on my NA6 racer. The system goes 4-2-1 extractors>2.5" press bent pipe>hot dog resonator>2.5" press bent pipe>straight through muffler>2.5" press bent pipe tip.
The sound is raspy but you can tell there isn't much restriction to breathing. Much better than stock. Comes in at 98db at Lakeside.
No power figures as the car came with a side exit muffler that was bashed and rooted (being so low, it's no surprise). I replaced it straight away.
- Boags
Oh, another thing. There used to be a flexy bend at the end of the extractors. That busted after a short detour on the grass at a race meeting so we ran without any rear section for the rest of the day.
NO top end power due to car pinging its head off. I'm guessing that had a lot to do with the O2 sensor being so close to the outside world. Maybe a bit of back pressure helps the sensor work properly. Your Miles May Vary.
Boags
Boags
I've seen one NB running with just a hotdog to a side exhaust. Blackflagged for noise. I don't think it gave it any gains anyway.
- 16bit
i just got rid of an exhaust that had an empty cat and muffler. more power but less torque. and it was very very noisy and annoying. don't do it.
It would just sound like a huge raspy fart at nearly 100db. Cop magnet.
- 16bit
very raspy and much louder then 100db. mine was 101 at 5krpm. would have got to 110 easy.
here's mine.
http://www.youtube.com/watch?v=Gn_UEYWNrX4
in a tunnel though.
here's mine.
in a tunnel though.
- AJ
Boags wrote:Maybe a bit of back pressure helps the engine work properly.
Boags
rectified & quoted for historical purposes
maybe I should quote your comments in mIRC for hysterical purposes Boags???...........no???
XMX5 Rogues
- Boags
AJ wrote:Boags wrote:Maybe a bit of back pressure helps the engine work properly.
Boags
rectified & quoted for historical purposes![]()
maybe I should quote your comments in mIRC for hysterical purposes Boags???...........no???![]()
Bite me.
PS: you are wrong.
bruce wrote:It would just sound like a huge raspy fart at nearly 100db. Cop magnet.
olboy wrote:its on a race only car.
olboy
didnt know there were any cops on the track
MXHEVN wrote:bruce wrote:It would just sound like a huge raspy fart at nearly 100db. Cop magnet.
Well there is the sound police! Can't exceed 95db at most tracks otherwise you get booted off. (At least you dont get a ticket, but you also cant race again till you quieten it down..)
